[gdal-dev] clang-tidy 23 bugprone-signed-bitwise and CPL_LSBINT32PTR macros
Even Rouault
even.rouault at spatialys.com
Mon May 11 05:28:45 PDT 2026
Please re-try with the latest pushed commit in the PR that should
hopefully make -Wsign-conversion happy
Le 11/05/2026 à 14:11, Andrew C Aitchison via gdal-dev a écrit :
> On Sun, 10 May 2026, Even Rouault wrote:
>> Andrew,
>> does https://github.com/OSGeo/gdal/pull/14524 fix the warning?
> With that change, clang-tidy is happy, but now the compile breaks if I
> use
> `clang++ -Wsign-conversion`:
> In file included from /usr/local/gdal/git.llvm/include/gdal_dataset.h:18:
> /usr/local/gdal/git.llvm/include/cpl_port.h:808:33: error: implicit
> conversion changes signedness: 'int' to 'uint32_t' (aka 'unsigned int')
> [-Werror,-Wsign-conversion]
> 808 | uint32_t unsigned_val = CPL_LSBINT32PTR(x);
> /usr/local/gdal/git.llvm/include/cpl_port.h:788:62: note: expanded
> from macro
> 'CPL_LSBINT32PTR'
> 786 | ((*CPL_REINTERPRET_CAST(const GByte *, x))
> 787 | (*((CPL_REINTERPRET_CAST(const GByte *, x)) + 1) << 8)
> 788 | (*((CPL_REINTERPRET_CAST(const GByte *, x)) + 2) << 16)
> 789 | (*((CPL_REINTERPRET_CAST(const GByte *, x)) + 3) << 24))
> qed.cpp:122:30: note: in instantiation of function template
> specialization
> 'CPL_LSBSINT32PTR<unsigned char>' requested here
> 122 | return (static_cast<int>(CPL_LSBSINT32PTR(buf)));
>> Even
>> Le 10/05/2026 à 16:02, Andrew C Aitchison via gdal-dev a écrit :
>>> clang-tidy 23 (I'm using Ubuntu 26.04 with build
>>> ++20260508083129+d791e3a6f4c8-1~exp1~20260508083148.481
>>> from llvm-toolchain-snapshot at https://www.llvm.org/)
>>> has a new? check bugprone-signed-bitwise.
>>> This check objects to macros like CPL_LSBINT32PTR:
>>> clang-tidy --config="{Checks: 'bugprone-signed-bitwise',
>>> CheckOptions:
>>> {bugprone-signed-bitwise.IgnorePositiveIntegerLiterals: true}}"
>>> frmts/raw/lcpdataset.cpp
>>> reports 63 warnings of [bugprone-signed-bitwise], starting with:
>>> /home/werdna/gdal/git/frmts/raw/lcpdataset.cpp:171:10: warning: use
>>> of a signed integer operand with a binary bitwise operator
>>> 171 | if ((CPL_LSBSINT32PTR(poOpenInfo->pabyHeader) != 20 &&
>>> /usr/local/gdal/git.llvm/include/cpl_port.h:799:53: note: expanded
>>> from macro 'CPL_LSBSINT32PTR'
>>> 799 | #define CPL_LSBSINT32PTR(x) CPL_STATIC_CAST(GInt32,
>>> CPL_LSBINT32PTR(x))
>>> /usr/local/gdal/git.llvm/include/cpl_port.h:786:6: note: expanded
>>> from macro 'CPL_LSBINT32PTR'
>>> 787 | (*((CPL_REINTERPRET_CAST(const GByte *, x)) + 1) << 8U)
>>> 16U) | \
>>> /usr/local/gdal/git.llvm/include/cpl_port.h:181:55: note: expanded
>>> from macro 'CPL_STATIC_CAST'
>>> 181 | #define CPL_STATIC_CAST(type, expr) static_cast<type>(expr)
>>> I suspect that default type-promotion from an unsigned GByte
>>> to a *signed* int does not help here.
>>> Not exactly a bug, but annoying.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
