[gdal-dev] Using GMT CPT file with gdal raster color
Even Rouault even.rouault at spatialys.com
Sun May 17 14:43:09 PDT 2026
Sean,
thanks for the report. Support for GMT .cpt files dates back to 2010 and
hasn't evolved much since. So I assume GMT .cpt format might have
changed a bit since then. I've submitted a fix in
https://github.com/OSGeo/gdal/pull/14595 to support new files. In the
mean time you can manually adjust your .cpt file to please current
released GDAL versions by:
- replacing slashed with space
- and removing the trailing " L"
Even
Le 17/05/2026 à 22:24, Sean King via gdal-dev a écrit :
> Hi folks,
> I'm using GMT version 6.6.0 and GDAL version 3.12.4. I have
> several CPT files that I generated in GMT using the makecpt command,
> such as:
> */gmt makecpt -T-120/120/10 -I -Crainbow -Z -Fr/*
> which generates the attached file. Then, I am trying to apply that
> color palette to a TIFF file using 'gdal raster color'. The
> documentation <https://gdal.org/en/stable/programs/gdaldem.html>
> states that
> */GMT .cpt palette files are also supported (COLOR_MODEL = RGB only)./*
> however, I continually get the error of
> */ERROR 1: No color association found in test.cpt/*
> When I dug into the GDAL source code for the GMT CPT parser here
> <https://github.com/OSGeo/gdal/blob/b3f839f2515b023e4a7cf099b7ce1626ccb24eac/gcore/gdalcolortable.cpp#L744>,
> it really does not seem to match up with the current implementation of
> GMT CPT files, even though the GDAL feature was added in the latest
> release. For instance, it uses space, comma, tab, and colon as
> delimiters, but no matter what flags I use for my GMT CPT generation,
> I get a backslash as the delimiter, as seen in the attached file.
> There are other inconsistencies as well.
> Am I missing something? I'm somewhat new to GDAL and GMT, so I'd
> appreciate any advice. Also, if this feature really to read GMT CPT
> files is not adequate, is there a better way to approach this? I
> essentially want to colorize a .grd file using gdal, so that I can
> then generate map tiles with it. I have the rest of the pipeline
> figured out, but I'm having issues with the color mapping. I wrote my
> own converter from GMT CPT to GDAL color file, but it's a bit
> buggy/hacky. I'm wondering if there is a more 'official' way to do this.
> Thanks!
> Sean
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Very grumpy about LLMs: FOSS is about increasing public capital,
not becoming enslaved to private equity of giga corporations
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260517/81d095c2/attachment.htm>
