[gdal-dev] GDAL using tcmalloc accumulates memory
Stelios Lagaras stelios.lagaras at gmail.com
Wed Nov 4 01:19:55 PST 2026
Hi everyone,
That's my first mail on gdal-dev list, thanks in advance for your
feedback/replies.
I have been using the GDAL's ubuntu images, which sets
LD_PRELOAD=libtcmalloc_minimal.so.4 using tcmalloc as per docs hint
Multi-threading
— GDAL documentation
<https://gdal.org/en/latest/user/multithreading.html#ram-fragmentation-and-multi-threading>
Now, when I deploy an intensive IO (/vsis3) workflow in a Kubernetes+Spark
Cluster,
I have observed memory accumulation behavior, which apparently leads to OOM
breakdowns. The workaround I've found is using a clean spark python process
with:
spark.python.worker.reuse=false, though I was curious to dive a bit further
and find the root-cause of the memory stacking.
After letting Opus 5.5 work in a long session, it came back with the
suggestion of opting for TCMALLOC_AGGRESSIVE_DECOMMIT=true which is
expected to address the memory issue.
Now my humble question, is that something that could be set as a default
env inside GDAL images? Could we add a note in the docs for awareness that
the current default behavior
together with Spark may raise this phenomenon?
Thank you,
Stelios
On Sat, Oct 31, 2026 at 4:45 PM Stelios Lagaras <stelios.lagaras at gmail.com>
wrote:
> Hi everyone,
> feedback/replies.
> LD_PRELOAD=libtcmalloc_minimal.so.4 using tcmalloc as per docs hint Multi-threading
> Cluster,
> OOM breakdowns. The workaround I've found is using a clean spark python
> process with:
> further and find the root-cause of the memory stacking.
> Thank you,
> Stelios
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20261104/a9ad6901/attachment.htm>
