[gdal-dev] GDAL using tcmalloc accumulates memory
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Nov 4 05:07:35 PST 2026
I don't see the point of setting a default value to an option without
knowing what is it doing, and if it is really solving a problem.
At least now people can find your comment and try it if they want to.
On Wed, 4 Nov 2026 at 10:20, Stelios Lagaras via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi everyone,
> That's my first mail on gdal-dev list, thanks in advance for your
> feedback/replies.
> I have been using the GDAL's ubuntu images, which sets
> LD_PRELOAD=libtcmalloc_minimal.so.4 using tcmalloc as per docs hint Multi-threading
> — GDAL documentation
> <https://gdal.org/en/latest/user/multithreading.html#ram-fragmentation-and-multi-threading>
> Now, when I deploy an intensive IO (/vsis3) workflow in a Kubernetes+Spark
> Cluster,
> I have observed memory accumulation behavior, which apparently leads to
> OOM breakdowns. The workaround I've found is using a clean spark python
> process with:
> spark.python.worker.reuse=false, though I was curious to dive a bit
> further and find the root-cause of the memory stacking.
> After letting Opus 5.5 work in a long session, it came back with the
> suggestion of opting for TCMALLOC_AGGRESSIVE_DECOMMIT=true which is
> expected to address the memory issue.
> Now my humble question, is that something that could be set as a default
> env inside GDAL images? Could we add a note in the docs for awareness that
> the current default behavior
> together with Spark may raise this phenomenon?
> Thank you,
> Stelios
> On Sat, Oct 31, 2026 at 4:45 PM Stelios Lagaras <stelios.lagaras at gmail.com>
> wrote:
>> Hi everyone,
>> feedback/replies.
>> Kubernetes+Spark Cluster,
>> process with:
>> Thank you,
>> Stelios
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20261104/f4091a5a/attachment.htm>
