[gdal-dev] Odd comment in ogr_spatialref.h for TransformBounds API
Javier Jimenez Shaw
j1 at jimenezshaw.com
Thu Nov 5 02:14:48 PST 2026
Would this way (coding language, not English) be easier?
"elseif the destination CRS is geographic, the first axis is latitude, ..."
I think the newline in between tries to make it more clear
On Thu, 5 Nov 2026, 10:32 Ray at Daylon via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> Hi everyone,
> ogr_spatialref.h (current github source, master) has a comment preceding
> the TransformBounds function which seems odd.
> /** \brief Transform boundary.
> * This method is the same as the C function OCTTransformBounds().
> * Transform boundary densifying the edges to account for nonlinear
> * transformations along these edges and extracting the outermost
> bounds.
> * * If the destination CRS is geographic, the first axis is
> longitude, *
> * and xmax < xmin then the bounds crossed the antimeridian.
> * In this scenario there are two polygons, one on each side of the
> * antimeridian. The first polygon should be constructed with (xmin,
> ymin,
> * 180, ymax) and the second with (-180, ymin, xmax, ymax).
> * * If the destination CRS is geographic, the first axis is latitude, *
> * and ymax < ymin then the bounds crossed the antimeridian.
> * antimeridian. The first polygon should be constructed with (ymin,
> xmin,
> * ymax, 180) and the second with (ymin, -180, ymax, xmax).
> If the destination CRS is geographic, how can the first axis be longitude
> and latitude?
> Ray
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20261105/9ad34ebb/attachment.htm>
