[gdal-dev] Odd comment in ogr_spatialref.h for TransformBounds API
Greg Troxel
gdt at lexort.com
Thu Nov 5 02:45:06 PST 2026
Javier Jimenez Shaw via gdal-dev <gdal-dev at lists.osgeo.org> writes:
> Would this way (coding language, not English) be easier?
> "elseif the destination CRS is geographic, the first axis is latitude, ..."
> I think the newline in between tries to make it more clear
Should the second block be "geometric" (assuming this is the same as
GEOGRAPHY vs GEOMETRY in PostGIS)?
