[gdal-dev] Odd comment in ogr_spatialref.h for TransformBounds API
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Nov 5 03:51:42 PST 2026
I don't know the distinction in PostGIS.
Here it is just making the difference between northing-easting and
easting-northing CRSs.
On Thu, 5 Nov 2026 at 11:45, Greg Troxel via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Javier Jimenez Shaw via gdal-dev <gdal-dev at lists.osgeo.org> writes:
> > Would this way (coding language, not English) be easier?
> > "elseif the destination CRS is geographic, the first axis is latitude,
> > I think the newline in between tries to make it more clear
> Should the second block be "geometric" (assuming this is the same as
> GEOGRAPHY vs GEOMETRY in PostGIS)?
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20261105/59f1c06d/attachment.htm>
