[gdal-dev] Tightening AI based submission policy
ElPaso elpaso at itopen.it
Fri Oct 16 00:09:32 PDT 2026
Il 16/10/26 01:12, Nyall Dawson via gdal-dev ha scritto:
> Hi list,
> I'd like to propose that the GDAL project tighten its current policy
> regarding submission of AI assisted contributions.
> Currently the proposal is per
> https://gdal.org/en/stable/community/ai_tool_policy.html#ai-tool-policy,
> which sounds like a fair and safe policy. However, we've seen the GDAL
> community torn apart recently even with this policy in place, so I'd
> argue that the policy is too permissive and is placing too much burden
> on project maintainers.
> I'd also argue strongly that there's been a net loss in the
> sustainability, stability and security of the GDAL project in recent
> months, as a direct result of this.
> For reference, the QGIS project introduced a moratorium on all forms
> of AI developed submissions (see
> https://github.com/qgis/QGIS-Enhancement-Proposals/blob/master/qep-408-ai-tool-policy.md),
> which is now quite a blunt policy: "No LLM, AI or agent assisted code
> contributions are allowed in the https://github.com/qgis/qgis
> repository. If we subsequently discover that you have used an AI, LLM,
> or any agent-based workflow for your contribution, you will be subject
> to code reversion and contributor rights sanctioning.".  This is
> intended as a way to block all forms of ai based submissions, until
> the project has had time to properly step back and thoughtfully see
> how they impact on open-source development (at which stages interested
> parties are invited to start discussions on how to suitably and
> sustainably loosen this policy).
> Perhaps a similar stance could be adapted for GDAL? To reiterate --
> this may not be a permanent, forever ban on AI based submissions. It's
> a moratorium designed to protect the project and community until we
> can move forward safely.
> Thoughts?
> Nyall
I am 100% ok with this policy change.
In QGIS we are still discussing whether to open the policy to allow AI
usage to a selected experienced developers but as long as the copyright
issue isn't resolved I believe we should stay with a strict NO AI
GENERATED OR WRITTEN CODE OR TEXT ARE ALLOWED.
Thank you Nyall for restarting this discussion!
Alessandro Pasotti
w3: www.itopen.it
