[gdal-dev] Tightening AI based submission policy
Andrew C Aitchison
gdal at aitchison.me.uk
Fri Oct 16 03:36:24 PDT 2026
On Fri, 16 Oct 2026, Nyall Dawson via gdal-dev wrote:
> Hi list,
> I'd like to propose that the GDAL project tighten its current policy
> regarding submission of AI assisted contributions.
> Currently the proposal is per
> https://gdal.org/en/stable/community/ai_tool_policy.html#ai-tool-policy,
> which sounds like a fair and safe policy. However, we've seen the GDAL
> community torn apart recently even with this policy in place, so I'd argue
> that the policy is too permissive and is placing too much burden on project
> maintainers.
> I'd also argue strongly that there's been a net loss in the sustainability,
> stability and security of the GDAL project in recent months, as a direct
> result of this.
GDAL or OSGEO more generally - I haven't seen anything on this list ?
> For reference, the QGIS project introduced a moratorium on all forms of AI
> developed submissions (see
https://github.com/qgis/QGIS-Enhancement-Proposals/blob/master/qep-408-ai-tool-policy.md),
> which is now quite a blunt policy: "No LLM, AI or agent assisted code
> contributions are allowed in the https://github.com/qgis/qgis repository.
> If we subsequently discover that you have used an AI, LLM, or any
> agent-based workflow for your contribution, you will be subject to code
> reversion and contributor rights sanctioning.". This is intended as a way
> to block all forms of ai based submissions, until the project has had time
> to properly step back and thoughtfully see how they impact on open-source
> development (at which stages interested parties are invited to start
> discussions on how to suitably and sustainably loosen this policy).
> Perhaps a similar stance could be adapted for GDAL? To reiterate -- this
> may not be a permanent, forever ban on AI based submissions. It's a
> moratorium designed to protect the project and community until we can move
> forward safely.
Is the problem copyright or reviewer resource ?
If it is reviewer resource, then in theory the current policy solves the
problem. If in practice that is not working, can we be sure that a total
moratorium will actually protect scarce maintainer effort ?
I have a driver that I would like to submit to GDAL once I have fixed
a long-standing bug which current stops it being of much use to anyone.
I have been weighing up using an AI or LLM to help me find the cause of
the issue. This change would mean I cannot ask an AI for help and then
submit the driver once I understand and take responsibility for its
suggestions.
Andrew C. Aitchison Kendal, UK
andrew at aitchison.me.uk
