[gdal-dev] Tightening AI based submission policy
ElPaso elpaso at itopen.it
Mon Oct 19 01:33:50 PDT 2026
Il 19/10/26 09:50, Seth G via gdal-dev ha scritto:
> Hi all,
> One key point that has been missed so far, and was detailed by Luis in
> the OSGeo discuss thread [1], was including LLM-generated code puts
> the entire project's licensing at risk. Until this risk becomes
> clearer, a ban on LLM generated code in GDAL seems the most prudent
> approach.
That's my main concern too, as I mentioned in:
https://lists.osgeo.org/pipermail/gdal-dev/2026-October/061759.html
> As I understand it, even with a QGIS type policy, developers are still
> free to use LLMs to help understand the GDAL codebase,
> assist with debugging, and provide code reviews on any proposed
> changes. Outside of new feature development, most issues typically
> only result in a few lines of code changes, so I don't see much
> advantage in using an LLMs/agents in this case.
The current wording in QGIS QEP 408 is "No LLM, AI or agent assisted
code contributions are allowed", to my understanding this rules out any
usage of AI.
I personally believe we should open it up to allow usage of any tool as
long as the code is not written by a machine but by a human, which seems
to be the pre-condition for any kind of copyright claim, this would
allow, for instance, the usage of LLMs to find bugs or to explain the
code or even to suggest a fix.
> For GDAL driver developers wishing to use LLMs, then these can be
> written as plugins in a separate repository, with different licensing.
> Looking at geospatial projects that allow LLM contributions, it is 2
> months since the last commit to oxigeo, and still only contributor [2].
> RustGIS (a very new project), is part of a GitHub organisation with a
> history of open source projects, and has a few more contributors. But
> looking at an pull request with 29 comments [3], it is bots talking to
> bots all the way down. Personally, I have no interest contributing to
> a project written and run by AI.
Neither do I.
Alessandro
> While this discussion is ongoing, I'm sure it would be appreciated if
> GitHub pull requests were not used as a battleground for different
> points of view, resulting in even more pressure on maintainers.
> Seth
> [1] https://lists.osgeo.org/pipermail/discuss/2026-October/040423.html
> [2] https://github.com/cool-japan/oxigeo/graphs/contributors?all=1
> [3] https://github.com/opengeos/RustGIS/pull/545
> On Sun, Oct 18, 2026, at 10:17 PM, Nyall Dawson via gdal-dev wrote:
>> On Mon, 19 Oct 2026, 6:03 am Kurt Schwehr, <schwehr at gmail.com> wrote:
>>     I believe the term is "meat proxy" :)
>>     https://not-an-llm.com/meat-based-llm-proxies /
>>     https://gruhn.me/blog/2026-08-03/
>> Ah that's right. Just treat it as proof of my humanity 😂
>> Nyall
>>     And that's basically what I was doing with
>>     https://gist.github.com/schwehr/aafff40637236e1ba924495a947e00ba
>>     But TIL https://en.wikipedia.org/wiki/Meat_puppet
>>     On Sun, Oct 18, 2026 at 12:41 PM Nyall Dawson via gdal-dev
>>     <gdal-dev at lists.osgeo.org> wrote:
>>         On Mon, 19 Oct 2026, 5:32 am Jan Heckman via gdal-dev,
>>             Don't know if I should burden you with this - am not
>>             involved party, interested only.
>>             But submitted the conversation (don't shoot me) to
>>             deepseek and got the following. It seems reasonable.
>>         That is literally the WORST thing you could have contributed
>>         to this discussion. 👎
>>         Regardless of the stance on AI contributions, it is NEVER
>>         appropriate or socially acceptable to be a meat puppet and
>>         share an llm response like this in a human led discussion.
>>         Nyall
>>             There is the gdal community, they have (probably) had
>>             some issues with ill advised pull requests containing
>>             'vibe coding'. But the going on regulating LLM
>>             contributions (direct or indirect) is clearly hard. What
>>             would you say about this?
>>               On the GDAL AI-contribution thread: a hard problem, and
>>               the mailing list shows why
>>             This is genuinely hard, and the thread is valuable
>>             precisely because it exposes how many /different/problems
>>             are being bundled under one policy question. My read of
>>             the exchange:
>>                 The strongest argument in the thread isn't "AI is
>>                 bad" — it's asymmetric review burden
>>             Greg Troxel and Javier Jimenez Shaw land the most
>>             defensible point: the cost of /producing/a submission has
>>             collapsed while the cost of /reviewing/it has not. A
>>             plausible-but-subtly-wrong, verbose PR costs a maintainer
>>             10–20x what a competent human-written patch does, because
>>             it must be fully understood and effectively rewritten.
>>             That's an economic argument about maintainer time, not an
>>             ideological one, and it survives regardless of how good
>>             the models get. Andrew Bell's point about test bloat
>>             (more test lines than code change, slowing an
>>             already-slow CI) is the same argument in a different
>>             register.
>>             Notably, Daniel Baston — an actual maintainer — says the
>>             current policy plus GitHub moderation tools (PR rate
>>             limits, CI pre-approval, bans) has been /sufficient/for
>>             him. That's important counter-evidence: the "burden"
>>             claim is not uniformly experienced, and the thread would
>>             be better if it surfaced concrete PRs rather than
>>             abstractions. Andrew Bell's closing request for real
>>             examples is exactly right.
>>                 The QGIS-style moratorium is a blunt instrument with
>>                 a real cost
>>             Nyall's proposal is honest about being a time-limited
>>             moratorium, not a forever ban, which is more defensible
>>             than a permanent prohibition. But Andrew C Aitchison's
>>             objection is the one I'd press hardest: /if the problem
>>             is reviewer resources, a total ban doesn't obviously
>>             protect reviewer resources/— it just relocates the
>>             judgment call to "did they use AI?", which is
>>             unverifiable and invites the same policing burden. And
>>             his concrete case — using an LLM to /find/a bug, then
>>             understanding and taking responsibility for the fix — is
>>             exactly the kind of use a blanket ban criminalizes. A
>>             policy that can't distinguish "LLM helped me debug, I
>>             understand and own this" from "agent spat out a 2000-line
>>             PR I never read" is doing blunt work where precision is
>>             available.
>>                 Michael Sumner's framing conflates things, and Greg's
>>                 three-way split is the right correction
>>             Sumner asks whether opposition is about quality or
>>             ideology, and suggests a blanket ban is "political
>>             action." Greg's decomposition — (1) dealing with LLM
>>             text, (2) LLM text damaging the project's social
>>             structure, (3) LLM use being bad for society — is the
>>             cleanest analytical move in the thread. Points (1) and
>>             (2) are sufficient to justify /some/policy without
>>             touching (3), and that matters: it means people who are
>>             enthusiastic LLM users (like Kurt Schwehr, who is candid
>>             about spending >90% of coding time directing agents) can
>>             still support a tightened policy on non-ideological grounds.
>>             Sumner's own position — "the outputs are so good I'm not
>>             going to stop" — is honest but is a statement about
>>             /his/experience producing code, not about the receiving
>>             end. Javier's distinction is the sharpest thing in the
>>             thread: /you/using an LLM on /your/project with care is
>>             not the same as /strangers/firing agents at
>>             /your/project. The externalities run one direction.
>>                 What a good policy probably looks like
>>             The thread implicitly sketches something better than
>>             either pole:
>>             1.
>>                 *Keep the current disclosure-based policy, but make
>>                 non-compliance cheap to close.*Greg's observation is
>>                 the operational crux: in proj and gdal, likely-LLM
>>                 PRs get labeled and left /open/. A policy whose
>>                 enforcement is "label and wait" is worse than useless
>>                 — it signals tolerance. The fix is procedural:
>>                 undisclosed/likely-LLM submissions get closed
>>                 quickly, not labeled and parked. That's a
>>                 moderation-culture change, not a policy-text change.
>>             2.
>>                 *Put the guidance where the models read it.*Kurt's
>>                 AGENTS.md idea is the most constructive proposal in
>>                 the thread. If the policy document is written for
>>                 humans and the agents never see it, you get exactly
>>                 the failure mode you're trying to prevent. A
>>                 well-edited AGENTS.md plus a blunter CONTRIBUTING.md
>>                 (his draft PR #15415) attacks the problem at the
>>                 source rather than at review time. Caveat: an
>>                 AGENTS.md is advisory to a stochastic system, not a
>>                 filter — it will improve the distribution, not
>>                 eliminate slop.
>>             3.
>>                 *Separate "disclosure + human ownership" from
>>                 "volume."*The defensible core rule is: /a named human
>>                 must write the issue/PR description, understand the
>>                 change, and take responsibility for it./That covers
>>                 Andrew Aitchison's debugging case, covers
>>                 translation/refactor use cases, and excludes
>>                 agent-fire-and-forget. Pair it with rate limits and
>>                 CI pre-approval (which Dan says already work) to
>>                 handle volume.
>>             4.
>>                 *Distinguish contribution types.*A driver submission
>>                 that a human has tested and understands is not the
>>                 same as a drive-by typo PR generated by an agent.
>>                 Policy that treats all code equally will either
>>                 over-block or under-block.
>>                 Where I'd push back on the thread
>>                 Nyall asserts "net loss in sustainability, stability
>>                 and security in recent months" and "community torn
>>                 apart" without examples. That may be true, but as
>>                 written it's an assertion that can't be evaluated —
>>                 and Daniel, a maintainer, disputes the burden
>>                 framing. The moratorium case needs evidence, not just
>>                 frustration.
>>                 The QGIS precedent is cited as if its bluntness were
>>                 a virtue; it's better read as "they hadn't solved the
>>                 hard part either."
>>                 Nobody has proposed a /measurement/: e.g.,
>>                 time-to-review or revert-rate on disclosed-AI vs.
>>                 human PRs. Without that, this debate will keep
>>                 cycling between "slop is drowning us" and "I just
>>                 close the slop."
>>                 Bottom line
>>             The moratorium is a defensible /emergency brake/if the
>>             maintainer burden is real and unmanageable — but the
>>             thread doesn't establish that it is, and one maintainer
>>             says it isn't. The more promising path is the unglamorous
>>             one the thread keeps circling: close non-compliant PRs
>>             fast instead of labeling them, write the policy for the
>>             agents as well as the humans, and make "a human owns and
>>             understands this" the load-bearing rule. That threads the
>>             needle between Nyall's protect-the-maintainers instinct
>>             and Aitchison's legitimate "I used a tool to debug, sue
>>             me" case — which a blanket ban cannot.
>>             On Sun, Oct 18, 2026 at 9:14 PM Andrew Bell via gdal-dev
>>                 On Sun, Oct 18, 2026 at 10:41 AM Greg Troxel via
>>                 gdal-dev <gdal-dev at lists.osgeo.org> wrote:
>>                     I think there are three issues, super roughly
>>                       - "dealing with LLM text"
>>                       - "LLM text in the project is bad for the
>>                     project's social structure"
>>                       - "a broad culture of LLM use is bad for society".
>>                     and I think you are referring the the third as
>>                     "ideological".  However,
>>                     I think most of the concerns are reachable from
>>                     the first two parts
>>                     alone.
>>                 I think this discussion is pretty difficult without
>>                 real examples. I've seen some translation and
>>                 updating of projects that seem pretty amazing. On the
>>                 other hand, most of the non-trivial fixes that I've
>>                 seen haven't been good IMO. We had one recently in
>>                 PDAL where the issue description was an outright lie.
>>                 Personally, I think a real person should *always*
>>                 write the descriptive text of an issue or a PR. If
>>                 they can't do that (succinctly), then they don't
>>                 understand enough to be submitting a PR. I'm also
>>                 concerned with test bloat. The GDAL CI loop takes
>>                 forever already and adding tests for small and
>>                 probably unimportant fixes (as AI seems set on doing)
>>                 only makes this worse -- sometimes there are way more
>>                 lines of test than code change. The tests become a
>>                 burden.
>>                 Anyway, perhaps someone could point out some AI PRs
>>                 that they think are OK and some that they find
>>                 objectionable so that the discussion can move beyond
>>                 the theoretical.
>>                 Andrew Bell
>>                 andrew.bell.ia at gmail.com
>>                 _______________________________________________
>>                 gdal-dev mailing list
>>                 https://lists.osgeo.org/mailman/listinfo/gdal-dev
Alessandro Pasotti
w3: www.itopen.it
