[geomoose-psc] Google Geocoder
    James Klassen
    klassen.js at gmail.com
    Fri Jul  1 07:35:35 PDT 2016
Do we know who was running geocoder.us?  Maybe we could get it fixed.
On Jul 1, 2016 05:03, "Dan Little" <theduckylittle at gmail.com> wrote:
> Hey Folks,
> geocoder.us appears to be defunct. The website doesn't load and there
> certainly does not appear to be any geocodes being returned.  This was
> our default geocoder.
> The other geocoder with which we have code is the Google Geocoder.
> I'm fixing it up right now to work (it wasn't) and to also include an
> appropriate credit/disclaimer.  However, I'm a bit worried as we are
> probably running afoul the Google TOS.  I see a few options:
> 1. Run with it. We're a very small fish in a very large pond.
> 2. Do not include a Geocoder by default but provide instructions for
> adding back in the Google geocoder (including setting an API key).
> This runs ... "less" afoul the TOS depending on how you read them.
> 3. Remove all the geocoders.  They're all broken.  Folks may not like
> to see the code disappear.
> Long term (and I will file a ticket to this regard) we should probably
> write our own Geocoder instructions or write a crappy
> DIY/off-the-shelf-libs geocoder that works with the default parcel
> data.
> Cheers,
> -Duck
> Reference tickets:
> - https://github.com/geomoose/geomoose/issues/150
> - https://github.com/geomoose/geomoose/issues/152
> geomoose-psc mailing list
> geomoose-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20160701/f30cc390/attachment.html>
More information about the geomoose-psc
