[geomoose-psc] Ubuntu 16.04/PHP MapScript
    Dan Little
    theduckylittle at gmail.com
    Wed Jun  1 15:05:34 PDT 2016
The 2.9 demo does not use SQLite if that's any consolation.  It uses
the new service.php which uses JSON as its storage medium.
On Wed, Jun 1, 2016 at 4:33 PM, Jim Klassen <klassen.js at gmail.com> wrote:
> On 06/01/2016 04:18 PM, TC Haddad wrote:
>> On Wed, Jun 1, 2016 at 2:08 PM, Jim Klassen <klassen.js at gmail.com
>> <mailto:klassen.js at gmail.com>> wrote:
>>     Not that it is surprising, but the rest of GeoMoose (non PHP)
>>     builds and runs fine on 16.04.
>>     There are multiple issues with our php code and PHP 7 unrelated to
>>     mapscript.
>> Yeah - my main point is that others have the same problem and there is
>> potential for a joint solution if there is enough perceived communal
>> benefit. But you point out that the timeline is messed up either way,
>> which seems like an unfixable problem...
>> I agree that  the new language option is more of a GM 3.0 type change.
>> Is there a complete list of what features are dependent on PHP
>> mapscript so we can itemize the damage and attempt a calculation of
>> effort needed for options (a) or (b)?
>> T
> The following all call mapscript directly:
> identify.php
> popups.php
> print_util.php
> query.php
> select.php
> service.php
> config.php
> In addition to the mapscript problem, it sounds like the sqlite driver
> might have changed as well and there are a bunch of smaller random
> things that don't work with PHP 7.
More information about the geomoose-psc
