[geomoose-psc] Ubuntu 16.04/PHP MapScript
James Klassen
klassen.js at gmail.com
Mon Jun 6 10:02:50 PDT 2016
Thanks to Kalxas, OSGeo Live 10.0 now has PHP 5.6 and PHP MapScript
available [1].
GeoMoose 2.9 appears to be working on OSGeo Live again!
[1] https://trac.osgeo.org/osgeo/ticket/1717
On Jun 1, 2016 17:05, "Dan Little" <theduckylittle at gmail.com> wrote:
> The 2.9 demo does not use SQLite if that's any consolation. It uses
> the new service.php which uses JSON as its storage medium.
> On Wed, Jun 1, 2016 at 4:33 PM, Jim Klassen <klassen.js at gmail.com> wrote:
> > On 06/01/2016 04:18 PM, TC Haddad wrote:
> >> On Wed, Jun 1, 2016 at 2:08 PM, Jim Klassen <klassen.js at gmail.com
> >> <mailto:klassen.js at gmail.com>> wrote:
> >> Not that it is surprising, but the rest of GeoMoose (non PHP)
> >> builds and runs fine on 16.04.
> >> There are multiple issues with our php code and PHP 7 unrelated to
> >> mapscript.
> >> Yeah - my main point is that others have the same problem and there is
> >> potential for a joint solution if there is enough perceived communal
> >> benefit. But you point out that the timeline is messed up either way,
> >> which seems like an unfixable problem...
> >> I agree that the new language option is more of a GM 3.0 type change.
> >> Is there a complete list of what features are dependent on PHP
> >> mapscript so we can itemize the damage and attempt a calculation of
> >> effort needed for options (a) or (b)?
> >> T
> > The following all call mapscript directly:
> > identify.php
> > popups.php
> > print_util.php
> > query.php
> > select.php
> > service.php
> > config.php
> > In addition to the mapscript problem, it sounds like the sqlite driver
> > might have changed as well and there are a bunch of smaller random
> > things that don't work with PHP 7.
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20160606/3c60c049/attachment.html>
More information about the geomoose-psc
