[geomoose-psc] Ubuntu 16.04/PHP MapScript
    Dan Little
    theduckylittle at gmail.com
    Mon Jun  6 10:03:26 PDT 2016
Did you find the issue for the encoding bugs?
On Mon, Jun 6, 2016 at 12:02 PM, James Klassen <klassen.js at gmail.com> wrote:
> Thanks to Kalxas, OSGeo Live 10.0 now has PHP 5.6 and PHP MapScript
> available [1].
> GeoMoose 2.9 appears to be working on OSGeo Live again!
> [1] https://trac.osgeo.org/osgeo/ticket/1717
> On Jun 1, 2016 17:05, "Dan Little" <theduckylittle at gmail.com> wrote:
>> The 2.9 demo does not use SQLite if that's any consolation.  It uses
>> the new service.php which uses JSON as its storage medium.
>> On Wed, Jun 1, 2016 at 4:33 PM, Jim Klassen <klassen.js at gmail.com> wrote:
>> > On 06/01/2016 04:18 PM, TC Haddad wrote:
>> >> On Wed, Jun 1, 2016 at 2:08 PM, Jim Klassen <klassen.js at gmail.com
>> >> <mailto:klassen.js at gmail.com>> wrote:
>> >>     Not that it is surprising, but the rest of GeoMoose (non PHP)
>> >>     builds and runs fine on 16.04.
>> >>     There are multiple issues with our php code and PHP 7 unrelated to
>> >>     mapscript.
>> >> Yeah - my main point is that others have the same problem and there is
>> >> potential for a joint solution if there is enough perceived communal
>> >> benefit. But you point out that the timeline is messed up either way,
>> >> which seems like an unfixable problem...
>> >> I agree that  the new language option is more of a GM 3.0 type change.
>> >> Is there a complete list of what features are dependent on PHP
>> >> mapscript so we can itemize the damage and attempt a calculation of
>> >> effort needed for options (a) or (b)?
>> >> T
>> > The following all call mapscript directly:
>> > identify.php
>> > popups.php
>> > print_util.php
>> > query.php
>> > select.php
>> > service.php
>> > config.php
>> > In addition to the mapscript problem, it sounds like the sqlite driver
>> > might have changed as well and there are a bunch of smaller random
>> > things that don't work with PHP 7.
> geomoose-psc mailing list
> geomoose-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-psc
More information about the geomoose-psc
