[geomoose-psc] Ubuntu 16.04/PHP MapScript
James Klassen
klassen.js at gmail.com
Mon Jun 6 10:04:02 PDT 2016
apt-get install php-mbstring
On Jun 6, 2016 12:03, "Dan Little" <theduckylittle at gmail.com> wrote:
> Did you find the issue for the encoding bugs?
> On Mon, Jun 6, 2016 at 12:02 PM, James Klassen <klassen.js at gmail.com>
> wrote:
> > Thanks to Kalxas, OSGeo Live 10.0 now has PHP 5.6 and PHP MapScript
> > available [1].
> > GeoMoose 2.9 appears to be working on OSGeo Live again!
> > [1] https://trac.osgeo.org/osgeo/ticket/1717
> > On Jun 1, 2016 17:05, "Dan Little" <theduckylittle at gmail.com> wrote:
> >> The 2.9 demo does not use SQLite if that's any consolation. It uses
> >> the new service.php which uses JSON as its storage medium.
> >> On Wed, Jun 1, 2016 at 4:33 PM, Jim Klassen <klassen.js at gmail.com>
> wrote:
> >> > On 06/01/2016 04:18 PM, TC Haddad wrote:
> >> >> On Wed, Jun 1, 2016 at 2:08 PM, Jim Klassen <klassen.js at gmail.com
> >> >> <mailto:klassen.js at gmail.com>> wrote:
> >> >> Not that it is surprising, but the rest of GeoMoose (non PHP)
> >> >> builds and runs fine on 16.04.
> >> >> There are multiple issues with our php code and PHP 7 unrelated
> to
> >> >> mapscript.
> >> >> Yeah - my main point is that others have the same problem and there
> is
> >> >> potential for a joint solution if there is enough perceived communal
> >> >> benefit. But you point out that the timeline is messed up either way,
> >> >> which seems like an unfixable problem...
> >> >> I agree that the new language option is more of a GM 3.0 type
> change.
> >> >> Is there a complete list of what features are dependent on PHP
> >> >> mapscript so we can itemize the damage and attempt a calculation of
> >> >> effort needed for options (a) or (b)?
> >> >> T
> >> > The following all call mapscript directly:
> >> > identify.php
> >> > popups.php
> >> > print_util.php
> >> > query.php
> >> > select.php
> >> > service.php
> >> > config.php
> >> > In addition to the mapscript problem, it sounds like the sqlite driver
> >> > might have changed as well and there are a bunch of smaller random
> >> > things that don't work with PHP 7.
> > geomoose-psc mailing list
> > geomoose-psc at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20160606/e05b6305/attachment.html>
More information about the geomoose-psc
