[geomoose-psc] Publishing the Ledger
Dan Little
theduckylittle at gmail.com
Mon Dec 11 10:17:17 PST 2017
I've created a Git repository on www.
1. I created a new 'ledger' account on www.
2. I initialized a bare git repo.
3. I put a new public key of mine into authorized_keys.
4. I added www as origin, and set it to master's upstream on my local clone.
5. There is a summary.py file that will summarize the CSV file.
If there's anyone (other than Jim) who would like me to add their public
key to the repo, please let me know. I will do so and send you the
appropriate git-clone command.
Cheers!
On Sat, Dec 9, 2017 at 12:36 PM, Jim Klassen <klassen.js at gmail.com> wrote:
> Ok. CSV or maybe even just markdown. Whatever keeps it simple.
> On 12/08/2017 01:47 PM, Dan Little wrote:
> CSV is fine with me as well. That does allow for easy diffing and use of
> spreadsheet programs as desired. I will probably also include a "check
> balance" Python script for doing some basic reporting. There are CLI and
> text based ledger programs. I really don't want to go deep into a format
> debate or over-do the accounting for what really is a simple
> money-in-money-out + voting record.
> In terms of backup and redundancy, I will have the repo cloned locally,
> which gets backed up regularly, and those who have interest will also be
> able to do pulls. The bank account should also have some information and
> I'll put Nancy and Steve's contact information in the repository so that if
> something unfortunate were to happen, someone will be able to pick up the
> torch and continue on.
> On Fri, Dec 8, 2017 at 11:55 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
>> Thanks for starting this Dan. Github doesn't seem quite right (unless
>> open source projects also got one private repo for security, finances,
>> and other non-public issues)
>> On Fri, Dec 8, 2017 at 7:25 AM, James Klassen <klassen.js at gmail.com>
>> wrote:
>> > Thoughts:
>> > A plain text format might be better suited with git. Org would be
>> ideal (it
>> I was also thinking of some form of text format.
>> > can save formulas and recalculate like spreadsheets) except for most of
>> the
>> > magic only works in emacs, and despite emacs clearly being the one true
>> > editor, I realize not everyone is ready to accept that yet. But, some
>> other
>> > format like CSV or markdown table could work too. Mostly, I'd like to
>> be
>> CSV is simple text and can still be used by spreadsheet programs.
>> > able to use diff/blame to make it easy to audit who changed what when.
>> Yes, changesets was the point. I suppose that there is not going to
>> be a lot of churn on this file so I could download 10 copies of binary
>> files and open and look at them. But that is using me (a human) to do
>> diffs.
>> > The geomoose.org server is only sporatically backed up right now
>> (mostly
>> > before and after larger system config changes and GeoMoose releases). I
>> > have been assuming the day to day changes are covered by what is on
>> github
>> > and people's local clones. Thus is this isn't living on github, we
>> should
>> > be extra sure we are maintaining a separate copies (that are kept up to
>> > date) off server.
>> > I have no problem with git over ssh (or git over email). That is how
>> it was
>> > designed to work in the first place. We could go as simple as using the
>> > geomoose account or even easily setup gitolite.
>> Every PSC meeting that has a report about finances could be a prompt
>> for PSC members to copy the repo somewhere.
>> > We should maybe look at using GPG signed commits (git commit -S) for
>> this
>> > repo.
>> Maybe. I don't expect that we'll have confusion over who is making
>> the commits.
>> Best regards, Eli
>> > On Dec 8, 2017 8:44 AM, "Dan Little" <theduckylittle at gmail.com> wrote:
>> >> Hey Folks,
>> >> I have put together the start of a 'ledger'. Right now it's a
>> spreadsheet
>> >> in .ODS format. Barring objections, I'd like to create a repository on
>> the
>> >> web-server which can be accessed over SSH to store the ledger. This
>> can
>> >> give folks who are interested access without putting _everything_ up on
>> >> GitHub.
>> >> For those interested, we have $1,126 available at present.
>> >> Thanks again!
>> >> _______________________________________________
>> >> geomoose-psc mailing list
>> >> geomoose-psc at lists.osgeo.org
>> >> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20171211/85e2252c/attachment.html>
More information about the geomoose-psc
