[geomoose-psc] https for geomoose.org
Dan Little
theduckylittle at gmail.com
Sat May 27 08:41:25 PDT 2017
Having it be in a consistent place ensures that we can always refer to that
URL and not worry what year the image happens to represent. Of course, the
link needs to change but there's tricks around that too.
On Sat, May 27, 2017 at 10:40 AM, James Klassen <klassen.js at gmail.com>
wrote:
> I don't see how it matters. It all lives in geomoose-website.git so
> either way it will grow the repo (by 9kB per year).
> On May 27, 2017 9:49 AM, "Dan Little" <theduckylittle at gmail.com> wrote:
>> Should we just make a stable "foss4g-next.png" on geomoose.org?
>> On Fri, May 26, 2017 at 7:39 PM, James Klassen <klassen.js at gmail.com>
>> wrote:
>>> Yep.
>>> On May 26, 2017 18:29, "Eli Adam" <eadam at co.lincoln.or.us> wrote:
>>>> On Thu, May 25, 2017 at 7:23 PM, Jim Klassen <klassen.js at gmail.com>
>>>> wrote:
>>>> > Looks like the "OpenStreetMap - Black and White" layer is the only one
>>>> > that isn't available over https. I have updated the rest of the
>>>> > externally referenced layers in master as well as the google maps API
>>>> > and copied the foss4g2017 logo internally.
>>>> Looks like this was for 2.# demo, not 3.0.
>>>> Eli
>>>> > On 05/25/2017 06:51 PM, Eli Adam wrote:
>>>> >> On Thu, May 25, 2017 at 4:53 AM, Dan Little <
>>>> >>> Sorry this is only a partial answer...
>>>> >>> We can move almost all of that stuff to schemaless urls. Simply
>>>> remove
>>>> >>> "http:" from the URL and they'll automatically switch between http
>>>> and
>>>> >>> https.
>>>> >>> On Wed, May 24, 2017 at 10:24 PM, Jim Klassen <klassen.js at gmail.com>
>>>> wrote:
>>>> >>>> I have enabled https on the *.geomoose.org sites. Besides
>>>> generally
>>>> >>>> being considered a good idea lately, and Let's Encrypt making it
>>>> trivial
>>>> >> Yes, good to use https, also if we use https, that is useful testing
>>>> >> for people who want to run with https.
>>>> >> Let's Encrypt is good but we need to have our automated renewal
>>>> >> working well. Some sites seem to never figure that out and are
>>>> always
>>>> >> down because of it.
>>>> >>>> and free to do so, the motivation is that some features in
>>>> GeoMoose 3.0,
>>>> >>>> most notably the "Find Me", are blocked by Chrome if they don't
>>>> >>>> originate from an a site served by https.
>>>> >>>> This does cause some warnings and blocking now from pulling things
>>>> in
>>>> >>>> from non-https external sites.
>>>> >>>> The FOSS4G image hosted at mapserver.org has no https equivalent
>>>> that I
>>>> >>>> have found. We could self host as an easy work around.
>>>> >> Seems that this should be hosted on http://2017.foss4g.org/ but that
>>>> >> isn't https either.
>>>> >>>> The Google maps API in 2.x is pulled in using
>>>> >>>> http://maps.googleapis.com and not https://maps.googleapis.com
>>>> (or
>>>> >>>> //maps.googleapis.com).
>>>> >>>> OpenStreetMap is pulled in from XYZ using http (defined in the
>>>> mapbook)
>>>> >>>> ArcGIS 9.3 Rest Example is pulled in using http.
>>>> >>>> Weather Radar is pulled in using http.
>>>> >>>> These will require a patches to all the active 2.x series branches
>>>> so
>>>> >>>> they are picked up in the demo.
>>>> >>>> There is probably more, but this is what I found in a quick test.
>>>> I
>>>> >>>> haven't checked if the remote sites are available over https or
>>>> not. If
>>>> >>>> they are not, are the mixed-content warnings acceptable?
>>>> >> If we are demonstrating an https instance, that doesn't really do it.
>>>> >>>> Other thoughts?
>>>> >> https is sometimes slower which could make the demo look slow but it
>>>> >> still seems plenty fast to me testing (although with many images http
>>>> >> that isn't really testing anything).
>>>> >> Thanks for doing this Jim.
>>>> >> Eli
>>>> >>>> _______________________________________________
>>>> >>>> geomoose-psc mailing list
>>>> >>>> geomoose-psc at lists.osgeo.org
>>>> >>>> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20170527/14975ae0/attachment.html>
More information about the geomoose-psc
