[geomoose-psc] Feedback in testing PROJ v5.0.0 with GeoMOOSE
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Mar 5 07:17:30 PST 2018
Unfortunately that is incorrect, what is likely happening in your case
is related to caching in your browser. You can read the long thread
starting at my report for the RC6 release (I was testing from source on
Ubuntu 14.04 and Windows) at
http://lists.maptools.org/pipermail/proj/2018-February/008082.html
This will break all MapServer (and GDAL, PostGIS, GRASS GIS,...)
services outputting to the Google "Web Mercator". You can read in that
thread how I asked for an immediate RC7 release with that fix.
The PROJ team chose to release anyway (the fix was actually applied to
master before the release, but it will be available to all in the 5.0.1
release).
I again encourage *everyone* to provide feedback directly to the PROJ
community (there is even a Github ticket, if you prefer to give feedback
that way instead): https://github.com/OSGeo/proj.4/issues/834
-jeff
On 2018-03-03 5:04 AM, Jim Klassen wrote:
> FYI: I built MapServer 7.0.7+g9297c, GDAL 2.2.3, r41553, and PROJ 5.0.0
> on Linux and it appears to work correctly with the GeoMoose3 demo.
> On 02/24/2018 05:56 PM, Jeff McKenna wrote:
>> Hi all,
>> I have been testing the RC5 package of the upcoming PROJ 5.0.0 release
>> (http://lists.maptools.org/pipermail/proj/2018-February/008045.html)
>> on Windows in the MS4W environment (with MapServer-branch-7-0 and GDAL
>> 2.2.3).
>> I was shocked when I loaded the GM3 demo in my browser and saw a
>> totally blank/white opening map image!!!?! (the normally green line
>> layer of parcels, from demo/parcels/parcels.map, did not appear)
>> I was stuck on that too long, wondering if I was somehow using the
>> wrong API for this new PROJ (see upcoming release notes at bottom of
>> http://lists.maptools.org/pipermail/proj/2018-February/007966.html),
>> and going down many rabbit holes with logs etc.
>> In the end.....if I zoom out then of course the parcels appear.
>> Can someone else confirm this? (it could of course only be happening
>> in my environment)
>> Does the stock GM3-demo opening map image appear normal for you, using
>> PROJ 5.0.0 RC5 ?
>> Please let me know.
>> Thanks!
>> (and now i can have a weekend, this was bugging me too much, ha!)
>> -jeff
More information about the geomoose-psc
