[geomoose-psc] [Geomoose-users] Add a language to GeoMoose
Eli Adam eadam at co.lincoln.or.us
Mon Dec 7 10:46:50 PST 2020
On Mon, Dec 7, 2020 at 10:28 AM James Klassen <klassen.js at gmail.com> wrote:
> Moving this to the PSC list for a procedural question:
> How should we apply the contribution guidelines to translation contributions?  In other words, when do translators need to accept the terms and be listed in the AUTHORS file?
Maybe we have a "Translators" section of the authors file?
Translators should accept the terms, although I would be fine with a
public acknowledgement of such in the public list archives.
> Our current practice is to have people submit a PR adding themselves to the AUTHORS file.
> Does this model for code (and docs?) fit for translators (who may be less comfortable working with git and submitting a PR than the typical code contributor)?
I think we will get more translations if we do that overhead for
people.  That would also let translators focus on translation.
Someone mentioned a French translation too, perhaps we should reach
out to them as well.  The more default languages included, the more
welcoming to more new users.
> Translations are sort of code (by implementation detail), sort of documentation, are mostly a statement of fact, but also could have a creative element.
Certainly a gray area, acknowledgement of the terms and a section in
the author file takes a conservative approach.
Eli
> On Mon, Dec 7, 2020, 08:29 Eli Adam <eadam at co.lincoln.or.us> wrote:
>> Hi Flavio,
>> Adding additional languages is great!  Can you open a Github issue
>> with it.json here, https://github.com/geomoose/gm3/issues?
>> It looks like placement of the language file has come up before,
>> https://github.com/geomoose/gm3/issues/544
>> And maybe we should actively call for additional translations there too!
>> Best regards, Eli
>> On Sun, Nov 29, 2020 at 11:43 PM flavio rigolon
>> <flavio.rigolon at gmail.com> wrote:
>> > Hi all,
>> >  I'm using GeoMoose 3.6.2 and I've added my own "it.json" (italian language).
>> > The default languages are stored in
>> > "/srv/geomoose/gm3-example/htdocs/geomoose/src/gm3/lang/" but
>> > following the instruction [1] is implied but not explicitly said that
>> > we have to copy the. json file in the "home" directory (i.e.
>> > "/srv/geomoose/gm3-example/htdocs/desktop"). So, in my case I've set
>> > the "app.js" file like this:
>> > var app = new gm3.Application({
>> > mapserver_url: CONFIG.mapserver_url,
>> > mapfile_root: CONFIG.mapfile_root,
>> > map: {
>> > scaleLine: {
>> > enabled: true,
>> > //    units: 'imperial'
>> > units: 'metric'
>> > lang: {
>> > it: './it.json',
>> > and it works fine.
>> > Is it the case of edit the page [1] to explicitly point where the
>> > .json file must be? (I think there is also a trivial typo error in the
>> > page title: "...langauge" should be "...language").
>> > I've translated the .json file in italian; do you think it could be
>> > share to give a base point for other italian users like the es.json
>> > one for spanish?
>> > my 2 cents
>> > best regards
>> > flavio
>> > [1] https://geomoose.github.io/gm3/howto/add-a-language.html
>> > /"\  ASCII Ribbon Campaign
>> > \ /  Respect for low technology.
>> >  X  Keep e-mail messages readable by any computer system.
>> > / \  Keep it ASCII.
>> > _______________________________________________
>> > Geomoose-users mailing list
>> > Geomoose-users at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/geomoose-users
> geomoose-psc mailing list
> geomoose-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
More information about the geomoose-psc mailing list
