[geomoose-psc] [Geomoose-users] Add a language to GeoMoose
TC Haddad tchaddad at gmail.com
Tue Dec 8 10:02:20 PST 2020
For visibility, the link to the "Add a Language Page" should probably be a
direct link sub bullet in the index:
https://geomoose.github.io/gm3/
Under the main "how to contribute to Geomoose" bullet.
As an aside - I'm not sure where things stand with reorganizing the docs,
but starting next week I should have some availability to help with this
task if you think I can help,
T
On Tue, Dec 8, 2020 at 9:44 AM Jim Klassen <klassen.js at gmail.com> wrote:
> On 12/7/20 3:18 PM, Eli Adam wrote:
> > On Mon, Dec 7, 2020 at 1:08 PM TC Haddad <tchaddad at gmail.com> wrote:
> >> Sounds good to me - users have probably translated into other languages
> that we might not know about, because not everyone knows or needs to ask on
> the list.
> >> Maybe there is a place on the website where we can add a more visible
> call for translations, with links to the steps, statement of terms and the
> authors list?
> > What do you think of here,
> > https://geomoose.github.io/gm3/howto/add-a-language.html assuming that
> > most people will start there to add their translation?  Hmm, that page
> > is not in the index which makes it pretty low visibility.  I guess we
> > are in the process of addressing some of our documentation indexing.
> That makes sense to me (or the equivalent place after the docs
> re-organization).
> >> On Mon, Dec 7, 2020 at 11:00 AM Jim Klassen <klassen.js at gmail.com>
> wrote:
> >>> On 12/7/20 12:46 PM, Eli Adam wrote:
> >>>> On Mon, Dec 7, 2020 at 10:28 AM James Klassen <klassen.js at gmail.com>
> wrote:
> >>>>> Moving this to the PSC list for a procedural question:
> >>>>> How should we apply the contribution guidelines to translation
> contributions?  In other words, when do translators need to accept the
> terms and be listed in the AUTHORS file?
> >>>> Maybe we have a "Translators" section of the authors file?
> >>>> Translators should accept the terms, although I would be fine with a
> >>>> public acknowledgement of such in the public list archives.
> >>> That seems reasonable.
> >>>>> Our current practice is to have people submit a PR adding themselves
> to the AUTHORS file.
> >>>>> Does this model for code (and docs?) fit for translators (who may be
> less comfortable working with git and submitting a PR than the typical code
> contributor)?
> >>>> I think we will get more translations if we do that overhead for
> >>>> people.  That would also let translators focus on translation.
> >>>> Someone mentioned a French translation too, perhaps we should reach
> >>>> out to them as well.  The more default languages included, the more
> >>>> welcoming to more new users.
> >>> I very much agree.  Particularly, as long as we still have a "paper
> trail" such as public acknowledgement on the list.
> >>>>> Translations are sort of code (by implementation detail), sort of
> documentation, are mostly a statement of fact, but also could have a
> creative element.
> >>>> Certainly a gray area, acknowledgement of the terms and a section in
> >>>> the author file takes a conservative approach.
> >>> That works for me.
> >>> Does anyone have any comments/objections?
> >>>> Eli
> >>>>> On Mon, Dec 7, 2020, 08:29 Eli Adam <eadam at co.lincoln.or.us> wrote:
> >>>>>> Hi Flavio,
> >>>>>> Adding additional languages is great!  Can you open a Github issue
> >>>>>> with it.json here, https://github.com/geomoose/gm3/issues?
> >>>>>> It looks like placement of the language file has come up before,
> >>>>>> https://github.com/geomoose/gm3/issues/544
> >>>>>> And maybe we should actively call for additional translations there
> too!
> >>>>>> Best regards, Eli
> >>>>>> On Sun, Nov 29, 2020 at 11:43 PM flavio rigolon
> >>>>>> <flavio.rigolon at gmail.com> wrote:
> >>>>>>> Hi all,
> >>>>>>>    I'm using GeoMoose 3.6.2 and I've added my own "it.json"
> (italian language).
> >>>>>>> The default languages are stored in
> >>>>>>> "/srv/geomoose/gm3-example/htdocs/geomoose/src/gm3/lang/" but
> >>>>>>> following the instruction [1] is implied but not explicitly said
> that
> >>>>>>> we have to copy the. json file in the "home" directory (i.e.
> >>>>>>> "/srv/geomoose/gm3-example/htdocs/desktop"). So, in my case I've
> set
> >>>>>>> the "app.js" file like this:
> >>>>>>> var app = new gm3.Application({
> >>>>>>> mapserver_url: CONFIG.mapserver_url,
> >>>>>>> mapfile_root: CONFIG.mapfile_root,
> >>>>>>> map: {
> >>>>>>> scaleLine: {
> >>>>>>> enabled: true,
> >>>>>>> //    units: 'imperial'
> >>>>>>> units: 'metric'
> >>>>>>> lang: {
> >>>>>>> it: './it.json',
> >>>>>>> and it works fine.
> >>>>>>> Is it the case of edit the page [1] to explicitly point where the
> >>>>>>> .json file must be? (I think there is also a trivial typo error in
> the
> >>>>>>> page title: "...langauge" should be "...language").
> >>>>>>> I've translated the .json file in italian; do you think it could be
> >>>>>>> share to give a base point for other italian users like the es.json
> >>>>>>> one for spanish?
> >>>>>>> my 2 cents
> >>>>>>> best regards
> >>>>>>> flavio
> >>>>>>> [1] https://geomoose.github.io/gm3/howto/add-a-language.html
> >>>>>>> /"\  ASCII Ribbon Campaign
> >>>>>>> \ /  Respect for low technology.
> >>>>>>>    X  Keep e-mail messages readable by any computer system.
> >>>>>>> / \  Keep it ASCII.
> >>>>>>> _______________________________________________
> >>>>>>> Geomoose-users mailing list
> >>>>>>> Geomoose-users at lists.osgeo.org
> >>>>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
> >>>>> geomoose-psc mailing list
> >>>>> geomoose-psc at lists.osgeo.org
> >>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20201208/975c5a1f/attachment.html>
More information about the geomoose-psc mailing list
