[geomoose-psc] Worked the AGM slide a bit.
Jim Klassen klassen.js at gmail.com
Fri Aug 27 12:09:14 PDT 2021
Not all of this needs to be on the slide, but this is what I see
happened in the last year or so:
Merged pull requests (features):
#608 fix bug caused by DuckDuckGo Privacy Essentials
#611,#612,#624 ... Convert docs from MarkDown to ReStructeredText.
Reorganize docs.
#615 Add Italian
#619 Add French
#620,#671,#677 WFS-T Editing
#622 Brazilian Portuguese
#623 USNG Map Collar
#626 Add automatic precision to Lat/Lon display
#627 Travis to GitHub Actions for CI
#643 Buffer All (for select results)
#644 Bounding Box and Z/Lon/Lat to loc paramater (to support opening
GeoMoose to a particular location via a link)
#659 Restore keyboard shortcuts to service form
#666 Switch to Libra.chat for project IRC
#674 Support multiple mapbooks
Merged pull requests (bugs):
#621 Fix missing extent limitation bug
#630 Fix errors when no selectable layers are available
#648 Consistently Buffer Point on Line/Point Queries
#649 High Resolution Prints
#661 Ensure default properties are saved to property
#664 Fix modify-selection bug
#665 Fix for non-English and null values in grid sort
#669 Add safety rails around the selection checks
#676 Fix state bug with zoom-to extent
Policy:
Decide how to handle translation contributions.
On 8/27/21 1:53 PM, Eli Adam wrote:
> On Fri, Aug 27, 2021 at 11:27 AM Basques, Bob (CI-StPaul)
> <bob.basques at ci.stpaul.mn.us <mailto:bob.basques at ci.stpaul.mn.us>> wrote:
>     Jim,
>     Any other incremental updates?
>     Eli,
>     I was planning on removing the old slide before the deadline.  It
>     could be left in though if that’s the plan.
> Yes, please remove the old slide before the deadline, that's a good
> plan.  It was just the labeling that confused me but go ahead and
> delete it before the deadline and that's good.
> Thanks, Eli
>     *From: *geomoose-psc <geomoose-psc-bounces at lists.osgeo.org
>     <mailto:geomoose-psc-bounces at lists.osgeo.org>> on behalf of Jim
>     Klassen <klassen.js at gmail.com <mailto:klassen.js at gmail.com>>
>     *Date: *Friday, August 27, 2021 at 1:00 PM
>     *To: *"geomoose-psc at lists.osgeo.org
>     <mailto:geomoose-psc at lists.osgeo.org>"
>     <geomoose-psc at lists.osgeo.org <mailto:geomoose-psc at lists.osgeo.org>>
>     *Subject: *Re: [geomoose-psc] Worked the AGM slide a bit.
>     *Think Before You Click: *This email originated *outside *our
>     organization.
>     Sorry, I meant to do this sooner, I've been busy this week.
>     Unless there are objections, I'll cut the 3.8.0 release this weekend.
>     On 8/27/21 11:12 AM, Eli Adam wrote:
>         Hi Bob,
>         That slide looks good to me.  I edited the
>         language/translation part a bit and rephrased the examples and
>         areas to help.  The only part that is unclear to me is the
>         labeling of the previous slide with a year (2020).  I consider
>         our current slide to be an update from whenever we last
>         updated (2019?) to present (8/2021) which includes 2020.
>         Thanks for doing this.
>          Best regards, Eli
>         On Fri, Aug 27, 2021 at 8:25 AM Basques, Bob (CI-StPaul)
>             Added a new slide:
>             https://docs.google.com/presentation/d/1brbBb7-sKRI6U4dZ7LKnBT_-NnWzyS2TaZqVXzy8RDo/edit?pli=1#slide=id.g1fa15ee990_0_0
>             <https://docs.google.com/presentation/d/1brbBb7-sKRI6U4dZ7LKnBT_-NnWzyS2TaZqVXzy8RDo/edit?pli=1#slide=id.g1fa15ee990_0_0>
>             Left the old on in for comparison for now.
>             Anything else need to go in there?
>             Bobb
>             _______________________________________________
>             geomoose-psc mailing list
>             https://lists.osgeo.org/mailman/listinfo/geomoose-psc
>             <https://lists.osgeo.org/mailman/listinfo/geomoose-psc>
>         https://lists.osgeo.org/mailman/listinfo/geomoose-psc  <https://lists.osgeo.org/mailman/listinfo/geomoose-psc>
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20210827/99b2fd9a/attachment.html>
More information about the geomoose-psc mailing list
