[geomoose-psc] Worked the AGM slide a bit.
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Fri Aug 27 13:01:33 PDT 2021
Got most of you list in there.
Bobb
Date: Friday, August 27, 2021 at 2:09 PM
To: "eadam at co.lincoln.or.us" <eadam at co.lincoln.or.us>, Bob Basques <bob.basques at ci.stpaul.mn.us>
Cc: "geomoose-psc at lists.osgeo.org" <geomoose-psc at lists.osgeo.org>
Subject: Re: [geomoose-psc] Worked the AGM slide a bit.
Think Before You Click: This email originated outside our organization.
Not all of this needs to be on the slide, but this is what I see happened in the last year or so:
Merged pull requests (features):
#608 fix bug caused by DuckDuckGo Privacy Essentials
#611,#612,#624 ... Convert docs from MarkDown to ReStructeredText. Reorganize docs.
#615 Add Italian
#619 Add French
#620,#671,#677 WFS-T Editing
#622 Brazilian Portuguese
#623 USNG Map Collar
#626 Add automatic precision to Lat/Lon display
#627 Travis to GitHub Actions for CI
#643 Buffer All (for select results)
#644 Bounding Box and Z/Lon/Lat to loc paramater (to support opening GeoMoose to a particular location via a link)
#659 Restore keyboard shortcuts to service form
#666 Switch to Libra.chat for project IRC
#674 Support multiple mapbooks
Merged pull requests (bugs):
#621 Fix missing extent limitation bug
#630 Fix errors when no selectable layers are available
#648 Consistently Buffer Point on Line/Point Queries
#649 High Resolution Prints
#661 Ensure default properties are saved to property
#664 Fix modify-selection bug
#665 Fix for non-English and null values in grid sort
#669 Add safety rails around the selection checks
#676 Fix state bug with zoom-to extent
Policy:
Decide how to handle translation contributions.
On 8/27/21 1:53 PM, Eli Adam wrote:
On Fri, Aug 27, 2021 at 11:27 AM Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us<mailto:bob.basques at ci.stpaul.mn.us>> wrote:
Jim,
Any other incremental updates?
Eli,
I was planning on removing the old slide before the deadline. It could be left in though if that’s the plan.
Yes, please remove the old slide before the deadline, that's a good plan. It was just the labeling that confused me but go ahead and delete it before the deadline and that's good.
Thanks, Eli
From: geomoose-psc <geomoose-psc-bounces at lists.osgeo.org<mailto:geomoose-psc-bounces at lists.osgeo.org>> on behalf of Jim Klassen <klassen.js at gmail.com<mailto:klassen.js at gmail.com>>
Date: Friday, August 27, 2021 at 1:00 PM
To: "geomoose-psc at lists.osgeo.org<mailto:geomoose-psc at lists.osgeo.org>" <geomoose-psc at lists.osgeo.org<mailto:geomoose-psc at lists.osgeo.org>>
Sorry, I meant to do this sooner, I've been busy this week. Unless there are objections, I'll cut the 3.8.0 release this weekend.
On 8/27/21 11:12 AM, Eli Adam wrote:
Hi Bob,
That slide looks good to me. I edited the language/translation part a bit and rephrased the examples and areas to help. The only part that is unclear to me is the labeling of the previous slide with a year (2020). I consider our current slide to be an update from whenever we last updated (2019?) to present (8/2021) which includes 2020.
Thanks for doing this.
Best regards, Eli
On Fri, Aug 27, 2021 at 8:25 AM Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us<mailto:bob.basques at ci.stpaul.mn.us>> wrote:
Added a new slide:
https://docs.google.com/presentation/d/1brbBb7-sKRI6U4dZ7LKnBT_-NnWzyS2TaZqVXzy8RDo/edit?pli=1#slide=id.g1fa15ee990_0_0
Left the old on in for comparison for now.
Anything else need to go in there?
Bobb
geomoose-psc mailing list
https://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20210827/9689f2f1/attachment-0001.html>
More information about the geomoose-psc
