[geomoose-psc] Pull Request Review Request!
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Aug 3 06:36:34 PDT 2026
Thanks Dan.  Regarding the LLM policy, I like the note from GDAL/EvanR
regarding unnecessary verbose comments etc as part of AI-generated pull
requests (I see this in MapServer often now):
"The typical high verbosity of LLM code and text is actively
discouraged. More code is more code to maintain."
(I added that into your pull request)
thanks,
-jeff
On 2026-08-02 1:54 p.m., Dan Little via geomoose-psc wrote:
> Hi Folks!
> I've got a few pull requests that have had some good work put into them,
> I think are good enhancements, and were also sponsored work. I'd love to
> get them reviewed, merged, and released.
> This is a "stack" of PRs that would add back the feature report:
> - https://github.com/geomoose/gm3/pull/999 <https://github.com/geomoose/
> gm3/pull/999> : Restores the "print to scale" functionality. I've
> updated this with the curated list from the PSC suggestions.
> - https://github.com/geomoose/gm3/pull/1000 <https://github.com/
> geomoose/gm3/pull/1000> : This is marked as merging into 999 because it
> made testing of the tick lines a bit easier. This cleans up the PDF
> scale line to match the updated scale line on the map. I feel this one
> is an easy one to review.
> - https://github.com/geomoose/gm3/pull/1013 <https://github.com/
> geomoose/gm3/pull/1013> : Last but not least, the return of the feature
> report! This adds a sample feature report and layout to the parcels
> layer along with all the appropriate docs.
> After some feedback from folks (DM/emails) I did take the time to
> "promote" the basemap toggle to a mainline component. I think the
> "experiemental" status made it scary and left us not testing it (which
> is why we needed a react 18 fix for it in the first place):
> - https://github.com/geomoose/gm3/pull/1015 <https://github.com/
> geomoose/gm3/pull/1015>
> Last but not least I've drafted a first AI/LLM policy here:
> - https://github.com/geomoose/gm3/pull/1016 <https://github.com/
> geomoose/gm3/pull/1016>
> Thanks y'all!
> geomoose-psc mailing list
> geomoose-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the geomoose-psc mailing list
