[geomoose-psc] Pull Request Review Request!
Dan Little
theduckylittle at gmail.com
Mon Aug 3 10:19:52 PDT 2026
Great addition! Thank you!
On Mon, Aug 3, 2026 at 8:46 AM Jeff McKenna via geomoose-psc <
geomoose-psc at lists.osgeo.org> wrote:
> Thanks Dan. Regarding the LLM policy, I like the note from GDAL/EvanR
> regarding unnecessary verbose comments etc as part of AI-generated pull
> requests (I see this in MapServer often now):
> "The typical high verbosity of LLM code and text is actively
> discouraged. More code is more code to maintain."
> (I added that into your pull request)
> thanks,
> -jeff
> On 2026-08-02 1:54 p.m., Dan Little via geomoose-psc wrote:
> > Hi Folks!
> > I've got a few pull requests that have had some good work put into them,
> > I think are good enhancements, and were also sponsored work. I'd love to
> > get them reviewed, merged, and released.
> > This is a "stack" of PRs that would add back the feature report:
> > - https://github.com/geomoose/gm3/pull/999 <https://github.com/geomoose/
> > gm3/pull/999> : Restores the "print to scale" functionality. I've
> > updated this with the curated list from the PSC suggestions.
> > - https://github.com/geomoose/gm3/pull/1000 <https://github.com/
> > geomoose/gm3/pull/1000> : This is marked as merging into 999 because it
> > made testing of the tick lines a bit easier. This cleans up the PDF
> > scale line to match the updated scale line on the map. I feel this one
> > is an easy one to review.
> > - https://github.com/geomoose/gm3/pull/1013 <https://github.com/
> > geomoose/gm3/pull/1013> : Last but not least, the return of the feature
> > report! This adds a sample feature report and layout to the parcels
> > layer along with all the appropriate docs.
> > After some feedback from folks (DM/emails) I did take the time to
> > "promote" the basemap toggle to a mainline component. I think the
> > "experiemental" status made it scary and left us not testing it (which
> > is why we needed a react 18 fix for it in the first place):
> > - https://github.com/geomoose/gm3/pull/1015 <https://github.com/
> > geomoose/gm3/pull/1015>
> > Last but not least I've drafted a first AI/LLM policy here:
> > - https://github.com/geomoose/gm3/pull/1016 <https://github.com/
> > geomoose/gm3/pull/1016>
> > Thanks y'all!
> > geomoose-psc mailing list
> > https://lists.osgeo.org/mailman/listinfo/geomoose-psc
> Jeff McKenna
> GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
> co-founder of FOSS4G
> http://gatewaygeo.com/
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20260803/83d4ca10/attachment.htm>
More information about the geomoose-psc
