[geomoose-psc] Release this week?
Christopher Hughes chughes at co.lincoln.or.us
Tue Oct 13 11:44:24 PDT 2026
Some things in my testing workflow (based on things that haven't worked in the past). I don't know what we can add or would want to add to tests. Most of these things haven't been an issue in a while.
-chain multiple identify/selections/searches together
      -confirm previous results are cleared when doing a new identify/selection/search
      -confirm all expected results are returned (i.e. search returns all results and not just results within the previous selection geometry)
-selections
      -click select, go back to catalog and turn off the layer that was going to be selected, return to the select tool (either by clicking on the super tab or the select tool in the toolbar), then do a selection - confirm it selects the chosen layer from the drop-down
            -currently this selects the layer that was turned off - i.e. this test should fail
-searches
      -run search that will return no results - on all search types
      -test search by list
-identify
      -try to identify an area without data and confirm 0 results are returned
-print
      -switch between different resolutions
      -confirm sketches render in prints
-Start Over
      -confirm clicking cancel doesn't start over
-basemap toggle
      -switch layer in toggle, switch layer in catalog (to one in toggle - confirm it switches it in the toggle), switch layer in catalog  (to one not in toggle - confirm it removes it in the toggle), switch layer in catalog to one in not in toggle and then switch it back on via toggle - confirm it turns off the layer in catalog and switches on the toggle layer
Chris Hughes
GIS Analyst
Lincoln County GIS Department
880 NE 7th St. l Newport, OR 97365
Tel: (541) 574 1283
From: geomoose-psc <geomoose-psc-bounces at lists.osgeo.org> on behalf of Dan Little via geomoose-psc <geomoose-psc at lists.osgeo.org>
Sent: Tuesday, October 13, 2026 10:11 AM
To: James Klassen <klassen.js at gmail.com>
Cc: geomoose-psc at lists.osgeo.org <geomoose-psc at lists.osgeo.org>
Subject: Re: [geomoose-psc] Release this week?
I'm not sure as to the complete reliability of these first rounds of tests. I configured and setup the playwright tests but then worked with some models to create some additional tests. The branch is here:
- https://github.com/geomoose/gm3/pull/1046
For folks who have some favorite workflows for testing, maybe we can automate it a little bit more so we have some higher confidence in the releases?
The list of tests current covered are (this list is LLM summarized):
  Core desktop tasks (desktop.spec.js)
  1. Layers and backgrounds: turn the Parcels layer off and back on, then switch backgrounds and confirm only one is on at a time.
  2. Identify: turn on Vector Parcels and confirm the outlines draw on the map. Click a parcel and check that its PIN and owner appear.
  3. Select, zoom, export, remove: draw a box to select parcels and zoom to one. Download the CSV and check it holds that parcel, then remove the
     parcel from the results.
  4. Buffer and feature report: buffer a selected parcel by 100 ft and run the new selection. Open the parcel's report and download it as a PDF.
  5. Print a map: set a title and portrait layout, then Cancel. Reopen Print and download the PDF.
  6. Empty selection (offline only): a query with no results shows a clear message.
  Follow-up desktop tasks (desktop-workflows.spec.js)
  1. Selection needs a shape: pressing Go with nothing drawn shows a warning and sends no query. Drawing a polygon then works.
  2. Sorting: clicking a column header sorts the rows up, then down, then back to the original order.
  3. PIN filter: filter to one PIN and check the CSV holds only that parcel. Cancel leaves the filter in place, and Clear brings back every result.
  4. Value range filter: set a range that hides every row, then clear it. All rows come back without a new server query.
  5. Hide grid and cancel removal: minimizing and restoring the grid loses nothing, and cancelling a removal keeps the parcel.
  6. Buffer all results: buffer every result, clear the results, then select again.
  7. Results report: filter the results, then print a results report as a PDF.
  8. Parcel search: an empty search asks for input. Searching an owner's name finds their parcel.
  9. Favorites, Visible and Catalog: add a favorite and hide a layer from the Visible tab. The other two tabs show the same state.
  10. Bookmark: zoom to a parcel and copy the bookmark link. Opening the link restores the layers and map location, even with local storage cleared.
  11. Identify after turning a layer off: after the layer is turned off, clicking the map shows no stale results and sends no new query.
  Mobile (mobile.spec.js, Pixel 7 with touch)
  1. Catalog and tools: open the catalog, turn a layer off and on, then switch to Identify and confirm the map is still usable.
  2. Identify (live only): tap a parcel and get real details from the server. Switch to the map and back, and the results are still there.
We can add some more tests based on what folks find valuable and/or what folks have found they do repeatedly.
On Mon, Oct 12, 2026 at 8:40 PM James Klassen via geomoose-psc <geomoose-psc at lists.osgeo.org<mailto:geomoose-psc at lists.osgeo.org>> wrote:
I have a couple main job projects due at the end of the month.  I can make a release, but testing it given the amount of change will likely take more time than I have until November.  If we want a release before then (and roughly equivalently before FOSS4G-NA), my testing will be limited.
On Mon, Oct 12, 2026 at 19:34 Eli Adam <eadam at co.lincoln.or.us<mailto:eadam at co.lincoln.or.us>> wrote:
I'm not in a rush if Jim will have a chance to look at it.  He has a different perspective on things that I often appreciate.
Our internal testing with beta testers will probably take more than a week.  Chris does have it up and running for those testers.
Eli
From: geomoose-psc <geomoose-psc-bounces at lists.osgeo.org<mailto:geomoose-psc-bounces at lists.osgeo.org>> on behalf of TC Haddad via geomoose-psc <geomoose-psc at lists.osgeo.org<mailto:geomoose-psc at lists.osgeo.org>>
Sent: Monday, October 12, 2026 9:03 AM
To: Jim Klassen <klassen.js at gmail.com<mailto:klassen.js at gmail.com>>
Cc: geomoose-psc at lists.osgeo.org<mailto:geomoose-psc at lists.osgeo.org> <geomoose-psc at lists.osgeo.org<mailto:geomoose-psc at lists.osgeo.org>>
I was going to remind everyone to do some testing this week ahead of the PSC meeting, now that all the major PRs have been merged.
Seems reasonable to give folks the week, discuss any issues that crop up on Friday, and then release at that point.
Tanya
On Mon, Oct 12, 2026 at 8:43 AM Jim Klassen via geomoose-psc <geomoose-psc at lists.osgeo.org<mailto:geomoose-psc at lists.osgeo.org>> wrote:
Has it been tested well enough for a release?  I haven't had a chance to
give it a thorough run through yet, but if others have, I'm happy to
mindlessly push the buttons to make a release.
On 10/12/26 10:19 AM, Dan Little via geomoose-psc wrote:
> Anyone have any objections to stamping a release from the current main
> branch?
> geomoose-psc mailing list
> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20261013/ad1183f9/attachment-0001.htm>
More information about the geomoose-psc mailing list
