[geomoose-psc] Release this week?
Dan Little theduckylittle at gmail.com
Mon Oct 19 04:25:21 PDT 2026
Chris' tests were added to the end to end testing suite! I'm going to work
on some automation this week.
On Tue, Oct 13, 2026 at 1:44 PM Christopher Hughes <chughes at co.lincoln.or.us>
wrote:
> Some things in my testing workflow (based on things that haven't worked in
> the past). I don't know what we can add or would want to add to tests. Most
> of these things haven't been an issue in a while.
> -chain multiple identify/selections/searches together
> -confirm previous results are cleared when doing a new
> identify/selection/search
> -confirm all expected results are returned (i.e. search returns all
> results and not just results within the previous selection geometry)
> -selections
> -click select, go back to catalog and turn off the layer that was going to
> be selected, return to the select tool (either by clicking on the super tab
> or the select tool in the toolbar), then do a selection - confirm it
> selects the chosen layer from the drop-down
> -currently this selects the layer that was turned off - i.e. this test
> should fail
> -searches
> -run search that will return no results - on all search types
> -test search by list
> -identify
> -try to identify an area without data and confirm 0 results are returned
> -print
> -switch between different resolutions
> -confirm sketches render in prints
> -Start Over
> -confirm clicking cancel doesn't start over
> -basemap toggle
> -switch layer in toggle, switch layer in catalog (to one in toggle -
> confirm it switches it in the toggle), switch layer in catalog  (to one not
> in toggle - confirm it removes it in the toggle), switch layer in catalog
> to one in not in toggle and then switch it back on via toggle - confirm it
> turns off the layer in catalog and switches on the toggle layer
> Chris Hughes
> GIS Analyst
> Lincoln County GIS Department
> 880 NE 7th St
> <https://www.google.com/maps/search/880+NE+7th+St?entry=gmail&source=g>.
> l Newport, OR 97365
> Tel: (541) 574 1283 <(541)%20574-1283>
> *From:* geomoose-psc <geomoose-psc-bounces at lists.osgeo.org> on behalf of
> Dan Little via geomoose-psc <geomoose-psc at lists.osgeo.org>
> *Sent:* Tuesday, October 13, 2026 10:11 AM
> *To:* James Klassen <klassen.js at gmail.com>
> *Cc:* geomoose-psc at lists.osgeo.org <geomoose-psc at lists.osgeo.org>
> *Subject:* Re: [geomoose-psc] Release this week?
> I'm not sure as to the complete reliability of these first rounds of
> tests. I configured and setup the playwright tests but then worked with
> some models to create some additional tests. The branch is here:
> - https://github.com/geomoose/gm3/pull/1046
> For folks who have some favorite workflows for testing, maybe we can
> automate it a little bit more so we have some higher confidence in the
> releases?
> The list of tests current covered are (this list is LLM summarized):
>   Core desktop tasks (desktop.spec.js)
>   1. Layers and backgrounds: turn the Parcels layer off and back on, then
> switch backgrounds and confirm only one is on at a time.
>   2. Identify: turn on Vector Parcels and confirm the outlines draw on the
> map. Click a parcel and check that its PIN and owner appear.
>   3. Select, zoom, export, remove: draw a box to select parcels and zoom
> to one. Download the CSV and check it holds that parcel, then remove the
>      parcel from the results.
>   4. Buffer and feature report: buffer a selected parcel by 100 ft and run
> the new selection. Open the parcel's report and download it as a PDF.
>   5. Print a map: set a title and portrait layout, then Cancel. Reopen
> Print and download the PDF.
>   6. Empty selection (offline only): a query with no results shows a clear
> message.
>   Follow-up desktop tasks (desktop-workflows.spec.js)
>   1. Selection needs a shape: pressing Go with nothing drawn shows a
> warning and sends no query. Drawing a polygon then works.
>   2. Sorting: clicking a column header sorts the rows up, then down, then
> back to the original order.
>   3. PIN filter: filter to one PIN and check the CSV holds only that
> parcel. Cancel leaves the filter in place, and Clear brings back every
> result.
>   4. Value range filter: set a range that hides every row, then clear it.
> All rows come back without a new server query.
>   5. Hide grid and cancel removal: minimizing and restoring the grid loses
> nothing, and cancelling a removal keeps the parcel.
>   6. Buffer all results: buffer every result, clear the results, then
> select again.
>   7. Results report: filter the results, then print a results report as a
> PDF.
>   8. Parcel search: an empty search asks for input. Searching an owner's
> name finds their parcel.
>   9. Favorites, Visible and Catalog: add a favorite and hide a layer from
> the Visible tab. The other two tabs show the same state.
>   10. Bookmark: zoom to a parcel and copy the bookmark link. Opening the
> link restores the layers and map location, even with local storage cleared.
>   11. Identify after turning a layer off: after the layer is turned off,
> clicking the map shows no stale results and sends no new query.
>   Mobile (mobile.spec.js, Pixel 7 with touch)
>   1. Catalog and tools: open the catalog, turn a layer off and on, then
> switch to Identify and confirm the map is still usable.
>   2. Identify (live only): tap a parcel and get real details from the
> server. Switch to the map and back, and the results are still there.
> We can add some more tests based on what folks find valuable and/or what
> folks have found they do repeatedly.
> On Mon, Oct 12, 2026 at 8:40 PM James Klassen via geomoose-psc <
> geomoose-psc at lists.osgeo.org> wrote:
> I have a couple main job projects due at the end of the month.  I can make
> a release, but testing it given the amount of change will likely take more
> time than I have until November.  If we want a release before then (and
> roughly equivalently before FOSS4G-NA), my testing will be limited.
> On Mon, Oct 12, 2026 at 19:34 Eli Adam <eadam at co.lincoln.or.us> wrote:
> I'm not in a rush if Jim will have a chance to look at it.  He has a
> different perspective on things that I often appreciate.
> Our internal testing with beta testers will probably take more than a
> week.  Chris does have it up and running for those testers.
> Eli
> TC Haddad via geomoose-psc <geomoose-psc at lists.osgeo.org>
> *Sent:* Monday, October 12, 2026 9:03 AM
> *To:* Jim Klassen <klassen.js at gmail.com>
> I was going to remind everyone to do some testing this week ahead of the
> PSC meeting, now that all the major PRs have been merged.
> Seems reasonable to give folks the week, discuss any issues that crop up
> on Friday, and then release at that point.
> Tanya
> On Mon, Oct 12, 2026 at 8:43 AM Jim Klassen via geomoose-psc <
> Has it been tested well enough for a release?  I haven't had a chance to
> give it a thorough run through yet, but if others have, I'm happy to
> mindlessly push the buttons to make a release.
> On 10/12/26 10:19 AM, Dan Little via geomoose-psc wrote:
> > Anyone have any objections to stamping a release from the current main
> > branch?
> > geomoose-psc mailing list
> > https://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20261019/13216c39/attachment-0001.htm>
More information about the geomoose-psc mailing list
