[Geomoose-users] Setting projection in GeoMoose
    Scott Oatley
    swoatley at gmail.com
    Fri Dec  7 18:57:28 EST 2007
Hi Jim,
In the configuration.js, you need to set MAP_COORDINATE_SYSTEM =
MNCOUNTY-DOUGLAS. That should support what you need... "to display the
lat-lon coordinates in the status bar and for passing lat-lon information
into a service."
Excerpt from the configuration.js reference guide:
var *MAP_COORDINATE_SYSTEM* = '<*UTM-zone*|MNCOUNTY-*COUNTYNAME*>';
Sets the coordinate system used when calculating geographic coordinates
(Lat/Long) displayed in the footer. Currently, only two coordinate systems
are supported. The demo default is UTM zone 15. *NOTE: This does not pertain
to the projection of your map layers.*
   - *UTM* Specify as UTM-<zone>, for example UTM-15.
   - *Minnesota County Coordinates* Specify as MNCOUNTY-<county name>,
   for example MNCOUNTY-RAMSEY.
-Scott Oatley
On Dec 7, 2007 3:06 PM, Jim Dahl <jim.dahl at mail.co.douglas.mn.us> wrote:
>  After reading the how to :
> http://www.geomoose.org:88/moose/documentation/how-tos/how-to-add-your-own-projection
>  I am still not sure what I have to do to set up my interface to use
> County Projected data.  I see the MN county projections are in the lib js
> file and the projection/MNcounty js file.  So that must leave the
> configuration js file where there is just one reference to UTM-15.  Is this
> something that is quick to do?
> Jim Dahl, GISP
> GIS Coordinator
> Douglas County Public Works
> 509 3rd Ave W
> PO Box 398
> Alexandria MN 56308
> V 320-762-2933
>    320-763-6001
> F 320-763-7955
> SF.Net email is sponsored by:
> Check out the new SourceForge.net Marketplace.
> It's the best place to buy or sell services for
> just about anything Open Source.
> http://sourceforge.net/services/buy/index.php
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071207/c41a5085/attachment.html
More information about the Geomoose-users
