[Geomoose-users] Setting projection in GeoMoose
Jim Dahl
jim.dahl at mail.co.douglas.mn.us
Mon Dec 10 09:51:30 EST 2007
Thanks, Scott. This was so easy so thanks to the documentation editors
and a red face to me for not finding it. I think for newcomers it seems
difficult to find the right information because it all seems a bit
overwhelming. When I performed the search, which is great to highlight
the searched for term, the Projection or Coodinate
(var MAP_COORDINATE_SYSTEM = '<UTM-zone|MNCOUNTY-COUNTYNAME>'; Sets the
coordinate system used when calculating geographic coordinates
(Lat/Long) displayed in the footer. Currently, only two coordinate
systems are supported. The demo default is UTM zone 15. NOTE: This does
not pertain to the projection of your map layers.)
didn't highlight for me so I must have missed it.
Jim
-----Original Message-----
Sent: Friday, December 07, 2007 5:57 PM
To: Jim Dahl
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Setting projection in GeoMoose
Hi Jim,
In the configuration.js, you need to set MAP_COORDINATE_SYSTEM =
MNCOUNTY-DOUGLAS. That should support what you need... " to display the
lat-lon coordinates in the status bar and for passing lat-lon
information into a service."
Excerpt from the configuration.js reference guide:
Sets the coordinate system used when calculating geographic
coordinates (Lat/Long) displayed in the footer. Currently, only two
coordinate systems are supported. The demo default is UTM zone 15. NOTE:
This does not pertain to the projection of your map layers.
* UTM Specify as UTM-<zone>, for example UTM-15.
* Minnesota County Coordinates Specify as MNCOUNTY-<county
name>, for example MNCOUNTY-RAMSEY.
-Scott Oatley
On Dec 7, 2007 3:06 PM, Jim Dahl
<jim.dahl at mail.co.douglas.mn.us> wrote:
After reading the how to :
http://www.geomoose.org:88/moose/documentation/how-tos/how-to-add-your-o
wn-projection
<http://www.geomoose.org:88/moose/documentation/how-tos/how-to-add-your-
own-projection> I am still not sure what I have to do to set up my
interface to use County Projected data. I see the MN county projections
are in the lib js file and the projection/MNcounty js file. So that
must leave the configuration js file where there is just one reference
to UTM-15. Is this something that is quick to do?
Jim Dahl, GISP
GIS Coordinator
Douglas County Public Works
509 3rd Ave W
PO Box 398
Alexandria MN 56308
V 320-762-2933
320-763-6001
F 320-763-7955
SF.Net email is sponsored by:
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071210/6e7d8c82/attachment.html
More information about the Geomoose-users
