[Geomoose-users] jpg, tif images / scale problem
Fischer, Brian
bfischer at houstonengineeringinc.com
Mon Nov 19 10:07:14 EST 2007
Try setting the status to "DEFAULT". I'm not sure what scripts need to
be changed in order to correctly calculate a scale for geographic
coordinates. Hopefully one of the other developers will help you out
with that.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Vojko
Daneu
Sent: Sunday, November 18, 2007 4:54 AM
To: GeoMOOSE
Subject: [Geomoose-users] jpg, tif images / scale problem
Hallo,
I have 2 questions regarding GeoMOOSE:
Question 1: is there any special procedure involved when loading and
showing image layers (tif,jpg) in GeoMoose?
I tried to load a map of the world (jpg-image - with jgw-file in the
same location) with the following .map file:
MAP
NAME 'mn_world'
SIZE 800 650
STATUS ON
EXTENT -180 -90 180 90
UNITS DD
IMAGETYPE JPEG
TRANSPARENT TRUE
WEB
INCLUDE "/ms4w/apps/GeoMOOSE/maps_statedemo/web_config.map"
END
LAYER
NAME 'world'
DATA './world.jpg'
TYPE RASTER
STATUS ON
END
END
I can see the layer's name in the "Map Layers" list on the right hand
side, but no image in the main window regardless of the zoom I use.
Question 2: I use the GeoMoose 1.0.0. example application and show
layers in geographic coordinates. The scale, shown in the footer is
obviously wrong. In which scripts do I have to change the code to get a
correct scale?
Best regards
Vojko
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071119/3739878a/attachment.html
More information about the Geomoose-users
