[Geomoose-users] ***PROBABLY FRAUD*** RE: Identifty tool:
Unable to interpret fields inraster files...
Athanasis Nikolaos
athanasis at geo.aegean.gr
Thu Nov 29 09:41:03 EST 2007
Thank you very much for your help,
Reading from the page http://mapserver.gis.umn.edu/docs/howto/raster_data, i realized that in a raster query the only fields I can obtain are:
x, y, value_list, value_n class red, green , blue.
Thus, there is no way to calculate other attributes from the raster image.
Athanasis Nikolaos
Adjunct Faculty and Ph.D. Candidate,
Department of Geography and Department of Cultural Technology and Communication
University of the Aegean
University Hill
81100 Mytilene, GREECE
TEL +30-22510-36436
Από: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Αποστολή: Τετ 28/11/2007 10:31 μμ
Προς: Athanasis Nikolaos; geomoose-users at lists.sourceforge.net
Θέμα: ***PROBABLY FRAUD*** RE: [Geomoose-users] Identifty tool: Unable to interpret fields inraster files...
Please refer to the MapServer help files for this. In this http://mapserver.gis.umn.edu/docs/howto/raster_data page it explains how to query raster data. Specifically look at section 8, it has an example of a template for raster queries. There is also additional info at http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?RasterQuery.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net [mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Athanasis Nikolaos
Sent: Tuesday, November 27, 2007 1:40 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Identifty tool: Unable to interpret fields inraster files...
Hello !
I am trying to use the identify tool in my geomoose application. It worked ok with shape files, until I tried to add a raster file in the identify.map file.
My problem is that when i click on the identify tool, then it does not know how to interpret the [ObjectID] field and it shows it as text, it does not show the number of the ObjectID., it shows exatly :
"[ObjectID]" as text.....
Here is the piece of the identify.map file:
LAYER
NAME 'ddd'
DATA 'county/dtm_lsv1.img'
STATUS ON
TYPE RASTER
TOLERANCE 1
TEMPLATE 'county/identify_DEM.html'
PROJECTION
"init=epsg:2100"
END
END
here is the identify_DEM.html file:
<tr>
<td colspan="2"><b>Test Layer</b></td>
</tr>
<tr>
<td align="right">ObjectID:</td>
<td>[ObjectID]</td>
</tr>
<tr><td colspan="2"><hr></td></tr>
here is my map file:
MAP
NAME 'please_run'
SIZE 800 650
#PROJECTION
# 'init=epsg:2100'
#END
STATUS ON
EXTENT 654482.650706199 4310740.53966996 729748.549950696 4366667.28424747
UNITS METERS
FONTSET '../fonts/fontset.list'
SYMBOLSET '../symbols/symbol.sym'
#TRANSPARENT TRUE
IMAGETYPE PNG
IMAGECOLOR 13 176 229
QUERYMAP
STATUS ON
STYLE SELECTED
END
WEB
LOG "/ms4w/apps/GeoMOOSE/maps_statedemo/the_log_file_does_not_work.log"
INCLUDE "/ms4w/apps/GeoMOOSE/maps_statedemo/web_config.map"
END
LEGEND
STATUS ON
END
LAYER
NAME 'DEM'
DATA 'dtm_lsv1.img'
STATUS DEFAULT
TYPE RASTER
#OFFSITE 0 0 0
PROJECTION
'init=epsg:2100'
END #PROJECTION
END #LAYER
END ## end Map
You can check what i mean in the following URL:
http://195.251.137.181/geomoose/statedemo.html
Use the identify tool and click where ever you want.... In tghe right panel you see the strange result....
Any hints please ???
Thank you very much in advance!
Athanasis Nikolaos
University Hill
TEL +30-22510-36436
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071129/fa265d9d/attachment.html
More information about the Geomoose-users
