[Geomoose-users] Identifty tool: Unable to interpret fields inraster files...
Fischer, Brian bfischer at houstonengineeringinc.com
Wed Nov 28 15:31:18 EST 2007
Please refer to the MapServer help files for this.  In this
http://mapserver.gis.umn.edu/docs/howto/raster_data page it explains how
to query raster data.  Specifically look at section 8, it has an example
of a template for raster queries.  There is also additional info at
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?RasterQuery.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of
Athanasis Nikolaos
Sent: Tuesday, November 27, 2007 1:40 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Identifty tool: Unable to interpret fields
inraster files...
Hello !
I am trying to use the identify tool in my geomoose application. It
worked ok with shape files, until I tried to add a raster file in the
identify.map file.
My problem is that when i click on the identify tool, then it does not
know how to interpret the [ObjectID] field and it shows it as text,  it
does not show the number of the ObjectID., it shows exatly :
"[ObjectID]" as text.....
Here is the piece of the identify.map file:
LAYER
NAME 'ddd'
DATA 'county/dtm_lsv1.img'
STATUS ON
TYPE RASTER
TOLERANCE 1
TEMPLATE 'county/identify_DEM.html'
PROJECTION
"init=epsg:2100"
END
END
here is the identify_DEM.html file:
<tr>
<td colspan="2"><b>Test Layer</b></td>
</tr>
<tr>
<td align="right">ObjectID:</td>
<td>[ObjectID]</td>
</tr>
<tr><td colspan="2"><hr></td></tr>
here is my map file:
MAP
NAME 'please_run'
SIZE 800 650
#PROJECTION
# 'init=epsg:2100'
#END
STATUS ON
EXTENT 654482.650706199 4310740.53966996 729748.549950696
4366667.28424747
UNITS METERS
FONTSET '../fonts/fontset.list'
SYMBOLSET '../symbols/symbol.sym'
#TRANSPARENT TRUE
IMAGETYPE PNG
IMAGECOLOR 13 176 229
QUERYMAP
STATUS ON
STYLE SELECTED
END
WEB
LOG "/ms4w/apps/GeoMOOSE/maps_statedemo/the_log_file_does_not_work.log"
INCLUDE "/ms4w/apps/GeoMOOSE/maps_statedemo/web_config.map"
END
LEGEND
STATUS ON
END
LAYER
NAME 'DEM'
DATA 'dtm_lsv1.img'
STATUS DEFAULT
TYPE RASTER
#OFFSITE 0 0 0
PROJECTION
'init=epsg:2100'
END #PROJECTION
END #LAYER
END ## end Map
You can check what i mean in the following URL:
http://195.251.137.181/geomoose/statedemo.html
Use the identify tool and click where ever you want.... In tghe right
panel you see the strange result....
Any hints please ???
Thank you very much in advance!
Athanasis Nikolaos
Adjunct Faculty  and Ph.D. Candidate,
Department of Geography and Department of Cultural Technology and
Communication
University of the Aegean
University Hill
81100 Mytilene, GREECE
TEL  +30-22510-36436
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071128/acca9b05/attachment.html
More information about the Geomoose-users mailing list
