[Geomoose-users] Identifty tool: Unable to interpret fields in
	raster files...
    Athanasis Nikolaos
    athanasis at geo.aegean.gr
    Tue Nov 27 14:40:28 EST 2007
Hello !
I am trying to use the identify tool in my geomoose application. It  worked ok with shape files, until I tried to add a raster file in the identify.map file.
My problem is that when i click on the identify tool, then it does not know how to interpret the [ObjectID] field and it shows it as text,  it does not show the number of the ObjectID., it shows exatly :
"[ObjectID]" as text.....
Here is the piece of the identify.map file:
LAYER
NAME 'ddd'
DATA 'county/dtm_lsv1.img'
STATUS ON
TYPE RASTER
TOLERANCE 1
TEMPLATE 'county/identify_DEM.html'
PROJECTION
"init=epsg:2100"
END
END
here is the identify_DEM.html file:
<tr>
<td colspan="2"><b>Test Layer</b></td>
</tr>
<tr>
<td align="right">ObjectID:</td>
<td>[ObjectID]</td>
</tr>
<tr><td colspan="2"><hr></td></tr>
here is my map file:
MAP
NAME 'please_run'
SIZE 800 650
#PROJECTION
# 'init=epsg:2100'
#END
STATUS ON
EXTENT 654482.650706199 4310740.53966996 729748.549950696 4366667.28424747
UNITS METERS
FONTSET '../fonts/fontset.list'
SYMBOLSET '../symbols/symbol.sym'
#TRANSPARENT TRUE
IMAGETYPE PNG
IMAGECOLOR 13 176 229
QUERYMAP
STATUS ON
STYLE SELECTED
END
WEB
LOG "/ms4w/apps/GeoMOOSE/maps_statedemo/the_log_file_does_not_work.log"
INCLUDE "/ms4w/apps/GeoMOOSE/maps_statedemo/web_config.map"
END
LEGEND
STATUS ON
END
LAYER
NAME 'DEM'
DATA 'dtm_lsv1.img'
STATUS DEFAULT
TYPE RASTER
#OFFSITE 0 0 0
PROJECTION
'init=epsg:2100'
END #PROJECTION
END #LAYER
END ## end Map
You can check what i mean in the following URL:
http://195.251.137.181/geomoose/statedemo.html
Use the identify tool and click where ever you want.... In tghe right panel you see the strange result....
Any hints please ???
Thank you very much in advance!
Athanasis Nikolaos
Adjunct Faculty  and Ph.D. Candidate,
Department of Geography and Department of Cultural Technology and Communication
University of the Aegean
University Hill
81100 Mytilene, GREECE
TEL  +30-22510-36436
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071127/a94754ab/attachment.html
More information about the Geomoose-users
