[Geomoose-users] ***PROBABLY FRAUD*** Re: Error in pdf-print module for point shapefiles when they use SYMBOL in the STY
Athanasis Nikolaos athanasis at geo.aegean.gr
Mon Nov 26 14:03:15 EST 2007
 thank you  for the very quick answer!
I use the  star symbol that comes with the symbol.sym file:
Symbol
Name 'star'
Type VECTOR
FILLED TRUE
Points
0 .375
.35 .375
.5 0
.65 .375
1 .375
.75 .625
.875 1
.5 .75
.125 1
.25 .625
END
END
I checked out that this error also happens with PIXMAP symbols. In advance, the problem also appears in  the DEMO map of Geomoose as well, when you zoom in and the little red stars appear on the screen. At this time, when you try to print then a internal server error appears.
Thank you again! Please any suggestions!
Athanasis Nikolaos
Adjunct Faculty  and Ph.D. Candidate,
Department of Geography and Department of Cultural Technology and Communication
University of the Aegean
University Hill
81100 Mytilene, GREECE
TEL  +30-22510-36436
Από: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Αποστολή: Δευ 26/11/2007 8:22 μμ
Προς: Athanasis Nikolaos
Κοιν.: geomoose-users at lists.sourceforge.net
Θέμα: ***PROBABLY FRAUD*** Re: [Geomoose-users] Error in pdf-print module for point shapefiles when they use SYMBOL in the STY
Athanasis,
Is it a raster symbol or a MapServer symbol?  If I had to guess, I would bet it was related to the symbol being a raster (bitmap) symbol, and the PDF maker having a hard time trying to apply that in the final output.  Either the Symbol can't be found or the name is referenced differently in more than one spot.
Can you send some more details about the symbol type.
bobb
>>> "Athanasis Nikolaos" <athanasis at geo.aegean.gr> wrote:
Hello,
I am facing the following problem: When I add a layer in the statedemo.xml file about points that uses a SYMBOL in its STYLE, then the whole map cannot be printed.
This appears ONLY in point shape files and ONLY if they use a SYMBOL and ONLY if the specific layer is active when you try to print the whole map!
The log file shows the following:
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181]     def draw(*args): return _mapscript.mapObj_draw(*args)\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] _mapscript.MapServerError: msDrawMap(): Image handling error. Failed to draw layer named 'dexamenes'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] msOGRFileOpen(): OGR error. Open failed for OGR connection `lesvos.mdb'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] Unable to initialize ODBC connection to DSN for DRIVER=Microsoft Access Driver (*.mdb);DBQ=lesvos.mdb,\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] [Microsoft][ODBC Microsoft Access Driver] Could not find file '(unknown)'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] \r, referer:
In my web browser i get an :"Internal Server error", when i print the map, and ONLY if the specific layer is active
The dexamenes.map file contains the following:
LAYER
NAME 'dexamenes'
CONNECTIONTYPE ogr
CONNECTION "lesvos.mdb"
DATA "DEXAMENES_LATH"
STATUS DEFAULT
TYPE Point
CLASS NAME ""
STYLE
SYMBOL star
COLOR 0 0 255
SIZE 10
END
END
PROJECTION
'init=epsg:2100'
END
END #LAYER
Please, does anyone know if there is a solution to this problem?
Thank you in advance,
Athanasis Nikolaos
University Hill
TEL  +30-22510-36436
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071126/30f88182/attachment.html
More information about the Geomoose-users mailing list
