[Geomoose-users] Error in pdf-print module for point
shape files when they use SYMBOL in the STY
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Mon Nov 26 13:22:54 EST 2007
Athanasis,
Is it a raster symbol or a MapServer symbol? If I had to guess, I
would bet it was related to the symbol being a raster (bitmap) symbol,
and the PDF maker having a hard time trying to apply that in the final
output. Either the Symbol can't be found or the name is referenced
differently in more than one spot.
Can you send some more details about the symbol type.
bobb
>>> "Athanasis Nikolaos" <athanasis at geo.aegean.gr> wrote:
Hello,
I am facing the following problem: When I add a layer in the
statedemo.xml file about points that uses a SYMBOL in its STYLE, then
the whole map cannot be printed.
This appears ONLY in point shape files and ONLY if they use a SYMBOL
and ONLY if the specific layer is active when you try to print the whole
map!
The log file shows the following:
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] def
draw(*args): return _mapscript.mapObj_draw(*args)\r, referer:
http://195.251.137.181/geomoose/statedemo.html
_mapscript.MapServerError: msDrawMap(): Image handling error. Failed to
draw layer named 'dexamenes'.\r, referer:
msOGRFileOpen(): OGR error. Open failed for OGR connection
`lesvos.mdb'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] Unable to
initialize ODBC connection to DSN for DRIVER=Microsoft Access Driver
(*.mdb);DBQ=lesvos.mdb,\r, referer:
[Microsoft][ODBC Microsoft Access Driver] Could not find file
'(unknown)'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] \r,
referer:
In my web browser i get an :"Internal Server error", when i print the
map, and ONLY if the specific layer is active
The dexamenes.map file contains the following:
LAYER
NAME 'dexamenes'
CONNECTIONTYPE ogr
CONNECTION "lesvos.mdb"
DATA "DEXAMENES_LATH"
STATUS DEFAULT
TYPE Point
CLASS NAME ""
STYLE
SYMBOL star
COLOR 0 0 255
SIZE 10
END
END
PROJECTION
'init=epsg:2100'
END
END #LAYER
Please, does anyone know if there is a solution to this problem?
Thank you in advance,
Athanasis Nikolaos
Adjunct Faculty and Ph.D. Candidate,
Department of Geography and Department of Cultural Technology and
Communication
University of the Aegean
University Hill
81100 Mytilene, GREECE
TEL +30-22510-36436
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071126/b3025491/attachment.html
More information about the Geomoose-users
