[Geomoose-users] Error in pdf-print module for point shape files
when they use SYMBOL in the STYLE element
Athanasis Nikolaos
athanasis at geo.aegean.gr
Mon Nov 26 12:51:33 EST 2007
Hello,
I am facing the following problem: When I add a layer in the statedemo.xml file about points that uses a SYMBOL in its STYLE, then the whole map cannot be printed.
This appears ONLY in point shape files and ONLY if they use a SYMBOL and ONLY if the specific layer is active when you try to print the whole map!
The log file shows the following:
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] def draw(*args): return _mapscript.mapObj_draw(*args)\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] _mapscript.MapServerError: msDrawMap(): Image handling error. Failed to draw layer named 'dexamenes'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] msOGRFileOpen(): OGR error. Open failed for OGR connection `lesvos.mdb'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] Unable to initialize ODBC connection to DSN for DRIVER=Microsoft Access Driver (*.mdb);DBQ=lesvos.mdb,\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] [Microsoft][ODBC Microsoft Access Driver] Could not find file '(unknown)'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] \r, referer:
In my web browser i get an :"Internal Server error", when i print the map, and ONLY if the specific layer is active
The dexamenes.map file contains the following:
LAYER
NAME 'dexamenes'
CONNECTIONTYPE ogr
CONNECTION "lesvos.mdb"
DATA "DEXAMENES_LATH"
STATUS DEFAULT
TYPE Point
CLASS NAME ""
STYLE
SYMBOL star
COLOR 0 0 255
SIZE 10
END
END
PROJECTION
'init=epsg:2100'
END
END #LAYER
Please, does anyone know if there is a solution to this problem?
Thank you in advance,
Athanasis Nikolaos
Adjunct Faculty and Ph.D. Candidate,
Department of Geography and Department of Cultural Technology and Communication
University of the Aegean
University Hill
81100 Mytilene, GREECE
TEL +30-22510-36436
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071126/59c91783/attachment.html
More information about the Geomoose-users
