[Geomoose-users] Error in pdf-print module for point shape
files when they use SYMBOL in the STY
Dan Little
danlittle at yahoo.com
Thu Nov 29 11:06:03 EST 2007
Actually it looks like the script is disagreeing with the use of an MDB/OGR layer. Brian, do you happen to have any UTM-15 Access/MDB format data that I could dump into the Demo app and do some testing?
-Duck
----- Original Message ----
To: Athanasis Nikolaos <athanasis at geo.aegean.gr>
Cc: geomoose-users at lists.sourceforge.net
Sent: Monday, November 26, 2007 12:22:54 PM
Subject: Re: [Geomoose-users] Error in pdf-print module for point shape files when they use SYMBOL in the STY
Athanasis,
Is it a raster symbol or a MapServer symbol? If I had to guess, I would bet it was related to the symbol being a raster (bitmap) symbol, and the PDF maker having a hard time trying to apply that in the final output. Either the Symbol can't be found or the name is referenced differently in more than one spot.
Can you send some more details about the symbol type.
bobb
>>> "Athanasis Nikolaos" <athanasis at geo.aegean.gr> wrote:
Hello,
I am facing the following problem: When I add a layer in the statedemo.xml file about points that uses a SYMBOL in its STYLE, then the whole map cannot be printed.
This appears ONLY in point shape files and ONLY if they use a SYMBOL and ONLY if the specific layer is active when you try to print the whole map!
The log file shows the following:
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] def draw(*args): return _mapscript.mapObj_draw(*args)\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] _mapscript.MapServerError: msDrawMap(): Image handling error. Failed to draw layer named 'dexamenes'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] msOGRFileOpen(): OGR error. Open failed for OGR connection `lesvos.mdb'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] Unable to initialize ODBC connection to DSN for DRIVER=Microsoft Access Driver (*.mdb);DBQ=lesvos.mdb,\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] [Microsoft][ODBC Microsoft Access Driver] Could not find file '(unknown)'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] \r, referer:
In my web browser i get an :"Internal Server error", when i print the map, and ONLY if the specific layer is active
The dexamenes.map file contains the following:
LAYER
NAME 'dexamenes'
CONNECTIONTYPE ogr
CONNECTION "lesvos.mdb"
DATA "DEXAMENES_LATH"
STATUS DEFAULT
TYPE Point
CLASS NAME ""
STYLE
SYMBOL star
COLOR 0 0 255
SIZE 10
END
END
PROJECTION
'init=epsg:2100'
END
END #LAYER
Please, does anyone know if there is a solution to this problem?
Thank you in advance,
Athanasis Nikolaos
Adjunct Faculty and Ph.D. Candidate,
Department of Geography and Department of Cultural Technology and Communication
University of the Aegean
University Hill
81100 Mytilene, GREECE
TEL +30-22510-36436
____________________________________________________________________________________
Be a better sports nut! Let your teams follow you
with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071129/e291a507/attachment.html
More information about the Geomoose-users
