[Geomoose-users] Error in pdf-print module for point shapefiles
when they use SYMBOL in the STY
Fischer, Brian
bfischer at houstonengineeringinc.com
Thu Nov 29 13:35:38 EST 2007
Yes, I can send you an mdb/ogr layer in UTM 15. My guess is that is an
ESRI geodatabase. I will email it to you offline.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Dan
Little
Sent: Thursday, November 29, 2007 10:06 AM
To: Bob Basques; Athanasis Nikolaos
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Error in pdf-print module for point
shapefiles when they use SYMBOL in the STY
Actually it looks like the script is disagreeing with the use of an
MDB/OGR layer. Brian, do you happen to have any UTM-15 Access/MDB
format data that I could dump into the Demo app and do some testing?
-Duck
----- Original Message ----
To: Athanasis Nikolaos <athanasis at geo.aegean.gr>
Sent: Monday, November 26, 2007 12:22:54 PM
Subject: Re: [Geomoose-users] Error in pdf-print module for point shape
Athanasis,
Is it a raster symbol or a MapServer symbol? If I had to guess, I would
bet it was related to the symbol being a raster (bitmap) symbol, and the
PDF maker having a hard time trying to apply that in the final output.
Either the Symbol can't be found or the name is referenced differently
in more than one spot.
Can you send some more details about the symbol type.
bobb
>>> "Athanasis Nikolaos" <athanasis at geo.aegean.gr> wrote:
Hello,
I am facing the following problem: When I add a layer in the
statedemo.xml file about points that uses a SYMBOL in its STYLE, then
the whole map cannot be printed.
This appears ONLY in point shape files and ONLY if they use a SYMBOL and
ONLY if the specific layer is active when you try to print the whole
map!
The log file shows the following:
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] def
draw(*args): return _mapscript.mapObj_draw(*args)\r, referer:
http://195.251.137.181/geomoose/statedemo.html
_mapscript.MapServerError: msDrawMap(): Image handling error. Failed to
draw layer named 'dexamenes'.\r, referer:
msOGRFileOpen(): OGR error. Open failed for OGR connection
`lesvos.mdb'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] Unable to
initialize ODBC connection to DSN for DRIVER=Microsoft Access Driver
(*.mdb);DBQ=lesvos.mdb,\r, referer:
[Microsoft][ODBC Microsoft Access Driver] Could not find file
'(unknown)'.\r, referer: http://195.251.137.181/geomoose/statedemo.html
[Mon Nov 26 19:39:53 2007] [error] [client 195.251.137.181] \r, referer:
In my web browser i get an :"Internal Server error", when i print the
map, and ONLY if the specific layer is active
The dexamenes.map file contains the following:
LAYER
NAME 'dexamenes'
CONNECTIONTYPE ogr
CONNECTION "lesvos.mdb"
DATA "DEXAMENES_LATH"
STATUS DEFAULT
TYPE Point
CLASS NAME ""
STYLE
SYMBOL star
COLOR 0 0 255
SIZE 10
END
END
PROJECTION
'init=epsg:2100'
END
END #LAYER
Please, does anyone know if there is a solution to this problem?
Thank you in advance,
Athanasis Nikolaos
Adjunct Faculty and Ph.D. Candidate,
Department of Geography and Department of Cultural Technology and
Communication
University of the Aegean
University Hill
81100 Mytilene, GREECE
TEL +30-22510-36436
Never miss a thing. Make Yahoo your homepage.
<http://us.rd.yahoo.com/evt=51438/*http://www.yahoo.com/r/hs>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071129/2d76280b/attachment.html
More information about the Geomoose-users
