[Geomoose-users] Help Please
Fischer, Brian bfischer at houstonengineeringinc.com
Thu Nov 29 13:34:24 EST 2007
Gary,
I looked and noticed your web object in the mapfile is blank.  I believe
at a minimum you need to have the Imagepath and ImageURL parameters.
Not sure if this is what is causing the error or not.
Yes you can select more than one polygon.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
-----Original Message-----
From: Gary Watry [mailto:watry at steam.coaps.fsu.edu]
Sent: Thursday, November 29, 2007 9:51 AM
To: Fischer, Brian
Cc: GeoMoose Users
Subject: Re: [Geomoose-users] Help Please
Attached are the files in zip format
can I select two ploygons?
Fischer, Brian wrote:
> Gary,
> Are you using MapServer 5.0?  Can you send your .map file it is having
> issues with?
> Brian Fischer
> Maple Grove, MN
> (763) 493-4522
> From: geomoose-users-bounces at lists.sourceforge.net
> [mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of
> Gary Watry
> Sent: Wednesday, November 28, 2007 12:17 PM
> To: GeoMoose Users
> Subject: [Geomoose-users] Help Please
> I have GeoMoose running on Linux (Centos 5) with the Sample Data
> When I "Select Features", I get the following:
> mapserv(): Web application error. Traditional BROWSE mode requires a
> TEMPLATE in the WEB section, but none was provided.
> What template am I missing and where does it go??
> Thanks
> SF.Net email is sponsored by: The Future of Linux Business White Paper
> from Novell.  From the desktop to the data center, Linux is going
> mainstream.  Let it simplify your IT future.
> http://altfarm.mediaplex.com/ad/ck/8857-50307-18918-4
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
