[Geomoose-users] Map Limits
Gary Watry watry at steam.coaps.fsu.edu
Thu Oct 18 09:47:21 EDT 2007
That did the trick, thanks
Fischer, Brian wrote:
> If I remember right this is set by the first <view> tag in the mapbook
> .xml file (statedemo.xml). We have been talking about moving it to a
> variable, but for now I believe that is where it needs to be set.
> Example below:
> <view title="Morton County" target="city" default="true"
> invisible="true">381591.716374519,5127642.28313768,263384.111679755,5207
> 746.49485987</view>
> You also will need to change the extent in the Full Extent button
> service at the top of the .xml file.
> Gary could you send these question to the GeoMOOSE mailing list, that
> way they will be in the archives for others to search if they have
> similar questions.  I watch the list pretty closely.
> P.S. Dan could you confirm?
> -Brian
> Brian Fischer
> Houston Engineering, Inc.
> Maple Grove, MN
> (763) 493-4522
> -----Original Message-----
> From: Gary Watry [mailto:watry at steam.coaps.fsu.edu]
> Sent: Thursday, October 18, 2007 7:52 AM
> To: Fischer, Brian
> Subject: Map Limits
> Where is the original map limits set
>     EXTENT 189783.560000 4816309.330000 761653.524114 5472346.500000
> I can change them in the individual map files, but not the over all
> display
More information about the Geomoose-users mailing list
