[Geomoose-users] Printing
Dan Little danlittle at yahoo.com
Tue Apr 15 10:05:50 EDT 2008
Jay this a problem between Screen and Print Resolutions.
Essentially there are two options:
Preserve the Extent of the map in the print out
-or-
Preserve the Scale of the map in the print out
We went with the first option since people generally want the view on the map to match the view on the print out.
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: "Fischer, Brian" <bfischer at houstonengineeringinc.com>; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Sent: Tuesday, April 15, 2008 7:58:37 AM
Subject: Re: [Geomoose-users] Printing
 _filtered {font-family:"Cambria Math";panose-1:2 4 5 3 5 4 6 3 2 4;}
 _filtered {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
 _filtered {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}
 _filtered {font-family:"Californian FB";panose-1:2 7 4 3 6 8 11 3 2 4;}
/* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", "sans-serif";}
a:link, span.MsoHyperlink
	{color:blue;text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;text-decoration:underline;}
p.MsoAcetate, li.MsoAcetate, div.MsoAcetate
	{margin:0in;margin-bottom:.0001pt;font-size:8.0pt;font-family:"Tahoma", "sans-serif";}
span.BalloonTextChar
	{font-family:"Tahoma", "sans-serif";}
span.balloontextchar0
span.EmailStyle20
	{font-family:"Calibri", "sans-serif";color:windowtext;}
span.EmailStyle21
	{font-family:"Arial", "sans-serif";color:navy;}
span.EmailStyle22
	{font-family:"Calibri", "sans-serif";color:#1F497D;}
.MsoChpDefault
	{font-size:10.0pt;}
 _filtered {margin:1.0in 1.0in 1.0in 1.0in;}
div.Section1
Yea if I zoom in they start to
appear…are there two different levels to set here….
I set the max extent to display on the labels the map file…but that does notseem to be the same as the Print PDF.
 Seems they are separate.  How
can I set this to where if they are seen in the map they will print on the map?
 THanks
 From: Fischer, Brian[mailto:bfischer at houstonengineeringinc.com]
Sent: Monday, April 14, 2008 7:55 PM
To: Jay Kapalczynski; geomoose-users at lists.sourceforge.net;geomoose-developers at lists.sourceforge.net
Subject: RE: [Geomoose-users] Printing
 It should print them.  What is the data source of those
labels?  It also could be a scale threshold happening.  If you zoom
in further do they appear on the .pdf?
From:geomoose-users-bounces at lists.sourceforge.net[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of JayKapalczynski
Sent: Monday, April 14, 2008 12:44 PM
To: geomoose-users at lists.sourceforge.net;geomoose-developers at lists.sourceforge.net
Subject: [Geomoose-users] Printing
 Does the printing not print the labels?
 THe house numbers see here are labeled from the Parcels
layer then map below (PDF) removes them?
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Skipped content of type multipart/related
More information about the Geomoose-users mailing list
