[Geomoose-users] [Geomoose-developers] Labeling
Dan Little
danlittle at yahoo.com
Tue Aug 5 16:45:26 EDT 2008
ANGLEITEM fieldname
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Sent: Tuesday, August 5, 2008 3:19:14 PM
Subject: Re: [Geomoose-users] [Geomoose-developers] Labeling
I have also tried Angle [Angle]
where “Angle” is the field name that holds the Degrees (ex 270)…still errors
out
Thoughts?
Can I even do what I am trying
to do?
From:geomoose-developers-bounces at lists.sourceforge.net
[mailto:geomoose-developers-bounces at lists.sourceforge.net] On Behalf Of Jay
Kapalczynski
Sent: Tuesday, August 05, 2008 1:36 PM
To: geomoose-users at lists.sourceforge.net;
Subject: [Geomoose-developers] Labeling
I have been successful labeling street centerlines using the
ANGLE FOLLOW in the .map File
This is being performed on a Shapefile Line feature
I also have a Polygon Feature that has a field that I am
trying to label….once again I need the text to follow the polygon
As you can see from the image the road names a following properly,
but the labels for the polygons are not following…
I tried the ANGLE FOLLOW on the Polygon and It will not
draw..
Is there some other syntax that I have to put in the map
file that will force the text to follow the Polygon?
THANKS
LAYER # Maple Grove Streets
Name
NAME Streets_Labels
DATA './GEOCODED_CENTERLINES2.shp'
STATUS DEFAULT
TYPE annotation
MAXSCALE 6000
MINSCALE 100
LABELITEM 'STREET_NAM'
LABELCACHE ON
CLASS
COLOR -1 -1 -1
LABEL
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 10
SIZE 8
MINSIZE 8
ANTIALIAS TRUE
COLOR 0 0 0
OUTLINECOLOR 255 255 192
BUFFER 2
END
END
END # Maple Grove
Streets Name
Skipped content of type multipart/related
More information about the Geomoose-users
