[Geomoose-users] Geomoose-users Digest, Vol 11, Issue 1
Fischer, Brian
bfischer at houstonengineeringinc.com
Wed Aug 6 11:20:01 EDT 2008
ANGLE FOLLOW will make a spline label that follows the line. ANGLE AUTO
will try to figure out the appropriate angle to put the text. You can
only use FOLLOW on line features.
-Brian
-----Original Message-----
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jim
Dahl
Sent: Tuesday, August 05, 2008 3:03 PM
To: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Geomoose-users Digest, Vol 11, Issue 1
Are angle follow and angle auto similar?
geomoose-users-request at lists.sourceforge.net
Sent: Tuesday, August 05, 2008 1:36 PM
Subject: Geomoose-users Digest, Vol 11, Issue 1
Send Geomoose-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.sourceforge.net/lists/listinfo/geomoose-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
geomoose-users-owner at lists.sourceforge.net
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Geomoose-users digest..."
Today's Topics:
1. GeoMoose and SDE (Jay Kapalczynski)
2. Re: GeoMoose and SDE (Dan Little)
3. Labeling (Jay Kapalczynski)
Message: 1
Date: Tue, 5 Aug 2008 11:03:25 -0500
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
Subject: [Geomoose-users] GeoMoose and SDE
To: <geomoose-users at lists.sourceforge.net>,
<geomoose-developers at lists.sourceforge.net>
Message-ID:
<A1124B79D79DED4C94FAAA6FEB9AE64604052B1A at mg-ex2k.ci.maple-grove.mn.us>
Content-Type: text/plain; charset="us-ascii"
Can GeoMoose read and display SDE datasets...
If so how do you write the .map file?
Any thoughts / Examples of a .map file?
Thanks
Message: 2
Date: Tue, 5 Aug 2008 10:57:52 -0700 (PDT)
Subject: Re: [Geomoose-users] GeoMoose and SDE
To: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>,
geomoose-users at lists.sourceforge.net,
Message-ID: <636382.30392.qm at web51410.mail.re2.yahoo.com>
Content-Type: text/plain; charset="windows-1252"
Hey Jay,
This is more of a MapServer question. But, I can say that is depends a
little on how you have SDE configured:
1) Configure SDE + ArcGIS Server to serve WMS - Then you access the
layers in GeoMOOSE just as you would any other WMS service. This is
kinda handy because you can style the layer with the ESRI tools and use
SDE, but you get to side-step the headaches of using ArcIMS (and it's
replacements).
2) Store the SDE database in Oracle. I'm not sure if MG is an Oracle
shop, but you can use SDE to store data in the Oracle SDO_GEOMETRY
format, which map server can also read.
3) Follow these directions:
http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#sde I
have no direct experience with following them so your mileage may vary a
bit.
----- Original Message ----
To: geomoose-users at lists.sourceforge.net;
Sent: Tuesday, August 5, 2008 11:03:25 AM
Can GeoMoose read and display SDE datasets?
Thanks
Message: 3
Date: Tue, 5 Aug 2008 13:35:50 -0500
Subject: [Geomoose-users] Labeling
Message-ID:
<A1124B79D79DED4C94FAAA6FEB9AE64604052B1E at mg-ex2k.ci.maple-grove.mn.us>
I have been successful labeling street centerlines using the ANGLE
FOLLOW in the .map File
This is being performed on a Shapefile Line feature
I also have a Polygon Feature that has a field that I am trying to
label....once again I need the text to follow the polygon
As you can see from the image the road names a following properly, but
the labels for the polygons are not following...
I tried the ANGLE FOLLOW on the Polygon and It will not draw..
Is there some other syntax that I have to put in the map file that will
force the text to follow the Polygon?
THANKS
LAYER # Maple Grove Streets Name
NAME Streets_Labels
DATA './GEOCODED_CENTERLINES2.shp'
STATUS DEFAULT
TYPE annotation
MAXSCALE 6000
MINSCALE 100
LABELITEM 'STREET_NAM'
LABELCACHE ON
CLASS
COLOR -1 -1 -1
LABEL
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 10
SIZE 8
MINSIZE 8
ANTIALIAS TRUE
COLOR 0 0 0
OUTLINECOLOR 255 255 192
BUFFER 2
END
END
END # Maple Grove Streets Name
Name: not available
Type: image/jpeg
Desc: image001.jpg
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge Build the coolest Linux based applications with Moblin SDK &
win great prizes Grand prize is a trip for two to an Open Source event
anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geomoose-users mailing list Geomoose-users at lists.sourceforge.net
End of Geomoose-users Digest, Vol 11, Issue 1
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
More information about the Geomoose-users
