[Geomoose-users] GeoMoose and SDE
Fischer, Brian
bfischer at houstonengineeringinc.com
Wed Aug 6 17:52:14 EDT 2008
Jay,
I would suggest posting the question out on the MapServer list. I do
know it depends on the SDE version you are using. I believe there are a
few examples on the mapserver web site also.
http://mapserver.gis.umn.edu/docs/reference/vector_data/arcsde
-Brian
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Dan
Little
Sent: Tuesday, August 05, 2008 12:58 PM
To: Jay Kapalczynski; geomoose-users at lists.sourceforge.net;
geomoose-developers at lists.sourceforge.net
Subject: Re: [Geomoose-users] GeoMoose and SDE
Hey Jay,
This is more of a MapServer question. But, I can say that is depends a
little on how you have SDE configured:
1) Configure SDE + ArcGIS Server to serve WMS - Then you access the
layers in GeoMOOSE just as you would any other WMS service. This is
kinda handy because you can style the layer with the ESRI tools and use
SDE, but you get to side-step the headaches of using ArcIMS (and it's
replacements).
2) Store the SDE database in Oracle. I'm not sure if MG is an Oracle
shop, but you can use SDE to store data in the Oracle SDO_GEOMETRY
format, which map server can also read.
3) Follow these directions:
http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#sde I
have no direct experience with following them so your mileage may vary a
bit.
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: geomoose-users at lists.sourceforge.net;
Sent: Tuesday, August 5, 2008 11:03:25 AM
Subject: [Geomoose-users] GeoMoose and SDE
Can GeoMoose read and display SDE datasets...
If so how do you write the .map file?
Any thoughts / Examples of a .map file?
Thanks
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080806/830fe7ce/attachment.html
More information about the Geomoose-users
