[Geomoose-users] Expressions
Jay Kapalczynski
jkapalczynski at ci.maple-grove.mn.us
Wed Aug 20 11:58:35 EDT 2008
As I said I am sorry for that....My bad...I understand you guys are out there helping...and I appreciate it....
Will not let that happen again...
Thank you for your thoughts, help and patience....
Sent: Wednesday, August 20, 2008 10:23 AM
To: Jay Kapalczynski; Fischer, Brian; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Subject: Re: [Geomoose-users] Expressions
Hey Jay,
What you want is what I wrote earlier. Please (and I'm saying this as nice as I can come up with to phrase right now), keep your confusion limited to one or two message list postings. I had to really struggle to go through all of them and determine which iteration of what particular solution you were trying.
MapServer will use a class without an expression as the "else" clause. So..
LAYER
CLASSITEM "DIAMETER"
CLASS
EXPRESSION '6'
... this won't render anything as there are no style/label directives ....
END
CLASS
# No Expression
LABEL
..... stuff you want in here.
END
END
END
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>; Dan Little <danlittle at yahoo.com>; "Fischer, Brian" <bfischer at houstonengineeringinc.com>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>; "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>
Sent: Wednesday, August 20, 2008 9:23:57 AM
Subject: RE: [Geomoose-users] Expressions
OK I got it to work....well got it label a specific value in the DIAMETER field.
Now is there is a way that I can write 2 EXPRESSIONS that will say don't label 6 and the second say label everything else?
Sent: Wednesday, August 20, 2008 9:17 AM
To: 'Dan Little'; Fischer, Brian; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
I get this to work:
But I get the errors when I try to create the expressions to limit what is labeled...(see former email below)
First off I am just trying to get the EXPRESSION to work for the labels.
Second I am trying to avoid writing 15 different expressions
That's why I was trying create an EXPRESSION that said label everything except values = 6
LAYER # Watermain_Pipe
#NAME Watermain_Pipe
DATA './watermain_pipes.shp'
STATUS DEFAULT
TYPE annotation
MAXSCALE 4000
MINSCALE 100
LABELITEM 'DIAMETER'
LABELCACHE ON
CLASS
LABEL
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 7
SIZE 7
MINSIZE 7
ANTIALIAS TRUE
COLOR 0 0 0
BUFFER 2
END
END
END
Sent: Wednesday, August 20, 2008 7:55 AM
To: Fischer, Brian; Jay Kapalczynski; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Actually, that will exclude anything with a 6 in it.
An easier way to go...
LAYER
CLASS
EXPRESSION '6'
# Leave this blank
END
CLASS
.... everything else ....
END
END
From: "Fischer, Brian" <bfischer at houstonengineeringinc.com>
To: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Sent: Tuesday, August 19, 2008 4:41:09 PM
I think that should do it.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: Jay Kapalczynski [mailto:jkapalczynski at ci.maple-grove.mn.us]
Sent: Tuesday, August 19, 2008 4:39 PM
To: Fischer, Brian; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Like this?
STATUS DEFAULT
TYPE annotation
MAXSCALE 4000
MINSCALE 100
#LABELITEM 'DIAMETER'
LABELCACHE ON
CLASS
LABEL
EXPRESSION /[^6]/
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 7
SIZE 7
MINSIZE 7
ANTIALIAS TRUE
COLOR 0 0 0
#OUTLINECOLOR 255 255 192
BUFFER 2
END
END
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Tuesday, August 19, 2008 4:13 PM
To: Jay Kapalczynski; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Yep, you just use a regular expression: /[^6]/
This is a mapserver syntax.
Brian Fischer
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net [mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jay Kapalczynski
Sent: Tuesday, August 19, 2008 4:08 PM
To: 'geomoose-users at lists.sourceforge.net'; 'geomoose-developers at lists.sourceforge.net'
Subject: [Geomoose-users] Expressions
Is there a way to form a NOT statement in the expression...
To say for instance...show me all but EXPRESSION "6"
Instead of having to write each one out that you want....say I have pipe sizes 1-30 but 90% are 6 inches....jsut show the ones that are not 6 iches...
This should decrease the amount of labeling I have to do
CLASS
LABEL
EXPRESSION "12"
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 7
SIZE 7
MINSIZE 7
ANTIALIAS TRUE
COLOR 0 0 0
BUFFER 2
END
END
CLASS
LABEL
EXPRESSION "16"
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 7
SIZE 7
MINSIZE 7
ANTIALIAS TRUE
COLOR 0 0 0
BUFFER 2
END
END
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080820/46b5ded8/attachment.html
More information about the Geomoose-users
