[Geomoose-users] Expressions
Dan Little danlittle at yahoo.com
Wed Aug 20 11:23:07 EDT 2008
Hey Jay,
What you want is what I wrote earlier.  Please (and I'm saying this as nice as I can come up with to phrase right now), keep your confusion limited to one or two message list postings.  I had to really struggle to go through all of them and determine which iteration of what particular solution you were trying.
MapServer will use a class without an expression as the "else" clause. So..
LAYER
    CLASSITEM "DIAMETER"
    CLASS
        EXPRESSION '6'
        ... this won't render anything as there are no style/label directives ....
    END
    CLASS
        # No Expression
        LABEL
            ..... stuff you want in here.
        END
    END
END
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>; Dan Little <danlittle at yahoo.com>; "Fischer, Brian" <bfischer at houstonengineeringinc.com>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>; "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>
Sent: Wednesday, August 20, 2008 9:23:57 AM
Subject: RE: [Geomoose-users] Expressions
OK I got it to work….well got it
label a specific value in the DIAMETER field.
Now is there is a way that I can
write 2 EXPRESSIONS that will say don’t label 6 and the second say label everything
else?
Sent: Wednesday, August 20, 2008 9:17 AM
To: 'Dan Little'; Fischer, Brian; geomoose-users at lists.sourceforge.net;
I get this to work:
But I get the errors when I try
to create the expressions to limit what is labeled…(see former email below)
First off I am just trying to
get the EXPRESSION to work for the labels.
Second I am trying to avoid
writing 15 different expressions
That’s why I was trying create
an EXPRESSION that said label everything except values = 6
LAYER # Watermain_Pipe
     #NAME Watermain_Pipe
     DATA './watermain_pipes.shp'
     STATUS DEFAULT
     TYPE annotation
    MAXSCALE 4000
    MINSCALE 100
    LABELITEM 'DIAMETER'
    LABELCACHE ON
CLASS
       LABEL
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 7
SIZE 7
MINSIZE 7
ANTIALIAS TRUE
COLOR 0 0 0
BUFFER 2
       END
     END
END
[mailto:danlittle at yahoo.com]
Sent: Wednesday, August 20, 2008 7:55 AM
To: Fischer, Brian; Jay Kapalczynski;
geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Subject: Re: [Geomoose-users] Expressions
Actually,
that will exclude anything with a 6 in it.
An easier way to go...
LAYER
    CLASS
       EXPRESSION '6'
        # Leave this blank
    END
    CLASS
           .... everything
else ....
    END
END
From: "Fischer, Brian" <bfischer at houstonengineeringinc.com>
Sent: Tuesday, August 19, 2008 4:41:09 PM
I think that should do it.
Brian
Fischer
Houston
Engineering, Inc.
Maple
Grove, MN
(763)
493-4522
[mailto:jkapalczynski at ci.maple-grove.mn.us]
Sent: Tuesday, August 19, 2008 4:39 PM
To: Fischer, Brian; geomoose-users at lists.sourceforge.net;
Like this?
      STATUS DEFAULT
      TYPE annotation
    MAXSCALE 4000
    MINSCALE 100
    #LABELITEM 'DIAMETER'
    LABELCACHE ON
CLASS
 LABEL
                                                EXPRESSION /[^6]/
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 7
SIZE 7
MINSIZE 7
ANTIALIAS TRUE
COLOR 0 0 0
#OUTLINECOLOR 255 255 192
BUFFER 2
END
     END
[mailto:bfischer at houstonengineeringinc.com]
Sent: Tuesday, August 19, 2008 4:13 PM
To: Jay Kapalczynski; geomoose-users at lists.sourceforge.net;
Yep, you just use a regular expression: /[^6]/
This is a mapserver syntax.
Brian
Fischer
Houston
Engineering, Inc.
Maple
Grove, MN
(763)
493-4522
From:geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jay
Kapalczynski
Sent: Tuesday, August 19, 2008 4:08 PM
To: 'geomoose-users at lists.sourceforge.net';
'geomoose-developers at lists.sourceforge.net'
Subject: [Geomoose-users] Expressions
Is there a way to form a NOT statement in the expression…
To say for instance…show me all but EXPRESSION “6”
Instead of having to write each one out that you want….say I
have pipe sizes 1-30 but 90% are 6 inches….jsut show the ones that are not 6
iches…
This should decrease the amount of labeling I have to do
     CLASS
           LABEL
        EXPRESSION "12"
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 7
SIZE 7
MINSIZE 7
ANTIALIAS TRUE
COLOR 0 0 0
BUFFER 2
         END
     END
     CLASS
         LABEL
        EXPRESSION "16"
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 7
SIZE 7
MINSIZE 7
ANTIALIAS TRUE
COLOR 0 0 0
BUFFER 2
         END
     END
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080820/59fdd868/attachment.html
More information about the Geomoose-users mailing list
