[Geomoose-users] [Geomoose-developers]  Mailing Labels
    Dan Little
    danlittle at yahoo.com
    Sat Mar 22 06:15:35 EDT 2008
Yes... you may not have FPDF installed.
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: "Fischer, Brian" <bfischer at houstonengineeringinc.com>; Dan Little <danlittle at yahoo.com>; geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
Sent: Friday, March 21, 2008 8:08:33 AM
Subject: RE: [Geomoose-developers] [Geomoose-users] Mailing Labels
 _filtered {font-family:"Cambria Math";panose-1:2 4 5 3 5 4 6 3 2 4;}
 _filtered {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
 _filtered {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Arial", "sans-serif";}
a:link, span.MsoHyperlink
	{color:blue;text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;text-decoration:underline;}
p.MsoAcetate, li.MsoAcetate, div.MsoAcetate
	{margin:0in;margin-bottom:.0001pt;font-size:8.0pt;font-family:"Tahoma", "sans-serif";}
span.BalloonTextChar
	{font-family:"Tahoma", "sans-serif";}
span.emailstyle17
	{font-family:"Arial", "sans-serif";color:windowtext;}
span.balloontextchar0
span.EmailStyle21
	{font-family:"Arial", "sans-serif";color:navy;}
span.EmailStyle22
	{font-family:"Calibri", "sans-serif";color:#1F497D;}
.MsoChpDefault
	{font-size:10.0pt;}
 _filtered {margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
I
think It is very usefuly on the select tool….I don’t nessessarly want to buffer
all the time….just a thought
 Any
reason for the Buffer Select not creating the PDF…when I save it, it has 0 file
size…
 Is
there something that would break the PDF and let the CSV work?
 I
get that error below when I use the Buffer Select tool and go to PDF
 Thougths?
 From: Fischer, Brian[mailto:bfischer at houstonengineeringinc.com]
Sent: Thursday, March 20, 2008 8:02 PM
To: Dan Little; Jay Kapalczynski;geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
 Dan you are
correct we never implemented the .cvs download and .pdf mailing label
generation for the select service.  We have talked about it but it would
take some more programming to make it happen.  I just must have forgot to
remove that from the select’s services header template.
 -Brian
From:geomoose-developers-bounces at lists.sourceforge.net [mailto:geomoose-developers-bounces at lists.sourceforge.net]On Behalf Of Dan Little
Sent: Thursday, March 20, 2008 7:00 PM
To: Jay Kapalczynski; geomoose-developers at lists.sourceforge.net;geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-developers] [Geomoose-users] Mailing Labels
 Idon't remember it EVER working with the select tool.
Brian, any thoughts?
To: geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
Sent: Thursday, March 20, 2008 11:40:00 AM
Subject: [Geomoose-users] Mailing Labels
 Mailing Labels….
WHen I do  a selection using the Buffer Select tool andclick CSV mailing labels everything is fine
 When I do a select using just the Select tooland then select CSV I get an error:
 This error is repeated EVERYTIME I try and send the mailinglabels to PDF as well…
 No Changes were made to any of these files except: Note the
CSV works fine on the Buffer Select but will not on the plain Select.
 $LABEL_LINES = array();
 $LABEL_LINES[0] = 'Owner Name';
 $LABEL_LINES[1] = '[HOUSENO]
[STREET]';
 $LABEL_LINES[2] = 'Maple Grove,
MN [ZIP]';
 Any thoughts?
 THanks
Lookingfor last minute shopping deals? Find
them fast with Yahoo! Search.
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
Skipped content of type multipart/related
More information about the Geomoose-users
