[Geomoose-users] New to GeoMoose.
Fischer, Brian
bfischer at houstonengineeringinc.com
Sun Mar 23 23:28:02 EDT 2008
Nelice,
Another thing to look for is to make sure you have your default extent
set to work with your coordinates. The default extent is the first set
of coordinates in the view element of the mapfile. You would also need
to change the mapfiles extent parameter to match that. Possible also
the units parameter in the mapfile as well. Also take a look at this
"how to"...it might need some updated but hopefully it will give you
some pointers.
http://www.geomoose.org/moose/documentation/how-tos/basic-how-to-add-you
r-own-data-layers/
If you still can't get it to work send the .xml file and one of your
mapfiles to the list and someone will likely help you out.
-Brian
-----Original Message-----
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Bob
Basques
Sent: Friday, March 21, 2008 9:43 AM
To: nellyfromma at gmail.com; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] New to GeoMoose.
Nelice?,
If you want to just get something up quick and dirty, I would just copy
the Demo folder so you have two complete installs, you will need to make
sure you name the two folders differently. Then get the demo running
under these two locations. Once you have that working, just swap out
the DATA parameter in the Mapfiles to you data, you can then turn off
(comment) or remove the layers in the demo that you don't want to see in
the interface.
bobb
**************** You can't be late until you show up. ***************
************ You never learn anything by doing it right. ************
*** War doesn't determine who's right. War determines who's left. ***
>>> "Nelson Soto" <nellyfromma at gmail.com> 03/21/08 8:18 AM >>>
Hello,
As I'm sure has been said many times, I am new to GeoMoose. I have
a limited set of experience with MapServer. I am running MS4W (on
Windows, naturally) and GeoMoose 1.2. I was able to get the county and
state demos running succesfully.
I was hoping to get to learn how to use GeoMoose by copying the
county directory to a new folder renamed to maps_medway (the demo I am
going to run will just display 3 or 4 layers of the town of Medway in
Massachusetts) and making copies of the html, xml, and .js files in
the webdocs folder. It's important to note that I did delete all of
the shape files for the counties and just mime'd the structure and
created 3 folders with their respected .shp's and .map's; a
landrecords folder with a parcel.shp, a a driveway folder with
driveway.shp and building folder with .shp.
I tried to replicate the formatting of the .map's that were present
in the county demo and attempted to substitute where necessary, but I
noticed a lot of inconsistencies in between different maps such as the
formatting of the DATA parameter where we point to the .shp. I have
reason to beleive this is where my main issue is.
I went through these files and ran searches for the word 'county'
and replaced it with the correct directories for my shape files. Some
of the .map files for the layers seem to point to
'/countydata/blah.shp' which is odd because that does not match the
folder structure that the files for the working demo actually were in
which leads me to bleive there is some way to define 'countydata' or
any other variable and then suppliment that with a directory.
I don't want anyone to do my work for me, I would just like a
little help in figuring this all out. I know, I should probably become
more familiar with Mapserver first before attempting to learn this but
I was able to generate images with these shp's just using the
mapserver cgi and had success in making VERY basic templates. I just
want to generate a proof of concept so that we can perhaps point more
of our resources (not just me :( ) to this.
I know, I'm a newbie, please forgive!
Thanks,
Nelice
This SF.net email is sponsored by: Microsoft
Defy all challenges. Microsoft(R) Visual Studio 2008.
http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
