[Geomoose-users] Custom Layer Not Loading
Clinton Olsen clinton at co.emery.ut.us
Wed Mar 26 12:49:57 EDT 2008
Brian,
Thanks for the help I figured out what was wrong.
Clinton Olsen
Emery County
IS/GIS Technician
(435) 381-5281
-----Original Message-----
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Wednesday, March 26, 2008 10:16 AM
To: Clinton Olsen
Cc: geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Custom Layer Not Loading
That error is basically telling you MapServer can't find the your mapfile.
Likely the path to that file is wrong or you have something misspelled.  If
you look in windows explorer what is your full path to the file?  Is there a
folder before the ms4w folder or is something spelled wrong?  Something like
C:/somefolder/ms4w/apps/GeoMOOSE.  If so that could be your issue.  MS4W and
GeoMOOSE expect the MS4W to be at the root of a drive.
Also please cc the list so the answers to these questions can be found by
others in the future.
Thanks,
Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
  _____
From: Clinton Olsen [mailto:clinton at co.emery.ut.us]
Sent: Wednesday, March 26, 2008 11:08 AM
To: Fischer, Brian
Brian,
Thanks for the suggestion.  Here is what I got when I used Firefox and
firebug.  When I tried to run the link below in a browser, I received this
message in the browser window: msLoadMap(): Unable to access file.
(/ms4w/apps/GeoMoose/MyMaps/roads.map)
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/GeoMoose/MyMaps/roads.ma
p
<http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/GeoMoose/MyMaps/roads.m
ap&mapext=1526238.5%207013167%202003498.5%207155757&mapsize=974%20291&mode=m
ap&MOOSETIME=1206547276515&layers>
&mapext=1526238.5%207013167%202003498.5%207155757&mapsize=974%20291&mode=map
&MOOSETIME=1206547276515&layers=
Any ideas on where I should look now?
Clinton Olsen
Emery County
IS/GIS Technician
(435) 381-5281
Sent: Tuesday, March 25, 2008 6:10 PM
To: Clinton Olsen; geomoose-users at lists.sourceforge.net
Hi Clinton,
It could be a projection or path issue.  Can you use firefox and firebug to
look at the source of the image that is not loading for you?  Then you can
take that URL and paste it into another browser window.  That should give
you some hints as to why the layer is not loading.  Hopefully this makes
sense, if not just say so and I can give some more detailed instructions.
-Brian
  _____
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Clinton
Olsen
Sent: Tuesday, March 25, 2008 5:22 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Custom Layer Not Loading
I have several mapserver applications that I built using the mapserver
tutorial.  Now I am desirous to add more features to the template, Geomoose
has the features that I need.  I followed the Geomoose tutorial, but when I
brought the countydemo page, my shapefile says it is loading but nothing
ever comes up.  Anyone have any ideas on how I can fix it?  Thanks.
Clinton Olsen
Emery County
IS/GIS Technician
(435) 381-5281
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080326/191e089c/attachment.html
More information about the Geomoose-users mailing list
