[Geomoose-users] RASTER & GEOmoose frustration
Fischer, Brian bfischer at houstonengineeringinc.com
Mon Mar 31 21:45:19 EDT 2008
Hose,
This is usually a good sign that your coordinate systems are different between you raster layers and your other data.  Do you know if everything is in the same coordinate system?
-Brian
From: geomoose-users-bounces at lists.sourceforge.net [mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Hose
Sent: Monday, March 31, 2008 9:07 AM
To: Bob Basques
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] RASTER & GEOmoose frustration
Thank you Sir,
I have tried the suggested /zindex =-1/ but without success.
It looks like the  raster image is loaded without any trouble the problem is that it only turns up a white layer or blank layer . The Fade/unfade option works on the raster layer so  when i place the raster on top of the list and turn any other layer underneath the raster on i can make the raster transparent and so other layers start showing through raster. So i can make it solid white or translucent but the DME raster image in tif, jpg,..... is simply not there. Only what it looks like a "Blank piece of paper" taht i can pan arround.
Thank you
 Sincerely Joze
Bob Basques <Bob.Basques at ci.stpaul.mn.us> wrote:
Joze,
First I would submit similar questions to the GeoMoose list, more info
here:
http://www.geomoose.org/moose/community-support/geomoose-mailing-list/
I'm copying this reply to the list.
It sounds like you need a ZINDEX=-1 parameter set in your MAPBOOK for
the Raster layer.
In the Demo package released with GeoMoose take a look at one of the
MAPBOOKS and do a search for "zindex", This parameter, tell the
GeoMoose application how to stack the layers in the interface by
default, setting the zindex to -1 will place that layer behind all
others as they are loaded, keep in mind that only one background layer
at a time can be used, but you can have as many set to -1 as you like.
All other layers that are not set to -1 will be place on top of the
interface.
You can also see the results in this interface by examining the Mapbook
(I would check with FireBug in Firefox if possible):
https://gis.ci.stpaul.mn.us/gis/gismo_public/html/
All the "Background" layer have a setting of "-1", which you can see
here:
https://gis.ci.stpaul.mn.us/datasets/CONFIGS/SAINT_PAUL/PUBLIC_WORKS/MAPBOOKS/TS/gismo3_public.xml
Excerpt from above:
â^'
â^'
/datasets/RASTER/SAINT_PAUL/PUBLIC_WORKS/AERIAL_CITIPIX/citipix_2001_public.map
â^'
â^'
/datasets/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1985_public.map
â^'
â^'
/datasets/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1974_public.map
â^'
â^'
/datasets/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1953_public.map
â^'
â^'
/datasets/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1940_public.map
hosejones1 at yahoo.com wrote:
> Dear Sir.
> My name is Joze. I am using ESRI Arcview, ArcMap..... at work. I have
a task to build a mapserver .
> I have chosed a MS4W instalation pack for Win. And GeoMoose
aplication. I have made the shapes and point layers to be working great.
I have not been so Lucky with RASTERS. I have tried to add .Jpg .GIF,
TIFF,..... nothing realy works. maybe its the problem with compsing my
.map file. I really dont have a slightest clue any more. I have been
searching the internet for quite a while an tried lots of things but
nothing really works for me. The closest i got to showing a raster over
geomoose is that when i put the raster on top i can fade and unfade
(transparency) it and the shape layers underneath shows up.
> I would really appreciate any help .
> Thank you
> Sincerely Joze
**************** You can't be late until you show up. ***************
************ You never learn anything by doing it right. ************
*** War doesn't determine who's right. War determines who's left. ***
No Cost - Get a month of Blockbuster Total Access <http://us.rd.yahoo.com/evt=47519/*http:/tc.deals.yahoo.com/tc/blockbuster/text1.com%0d%0a>  now. Sweet deal for Yahoo! users and friends.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080331/192664a1/attachment.html
More information about the Geomoose-users mailing list
