[Geomoose-users] RASTER & GEOmoose frustration
Hose hosejones1 at yahoo.com
Mon Mar 31 10:07:28 EDT 2008
Thank you Sir,
I have tried the suggested /zindex =-1/ but without success.
It looks like the  raster image is loaded without any trouble the problem is that it only turns up a white layer or blank layer . The Fade/unfade option works on the raster layer so  when i place the raster on top of the list and turn any other layer underneath the raster on i can make the raster transparent and so other layers start showing through raster. So i can make it solid white or translucent but the DME raster image in tif, jpg,..... is simply not there. Only what it looks like a "Blank piece of paper" taht i can pan arround.
Thank you
 Sincerely Joze
Bob Basques <Bob.Basques at ci.stpaul.mn.us> wrote: Joze,
First I would submit similar questions to the GeoMoose list, more info
here:
http://www.geomoose.org/moose/community-support/geomoose-mailing-list/
I'm copying this reply to the list.
It sounds like you need a ZINDEX=-1 parameter set in your MAPBOOK for
the Raster layer.
In the Demo package released with GeoMoose take a look at one of the
MAPBOOKS and do a search for "zindex",  This parameter, tell the
GeoMoose application how to stack the layers in the interface by
default, setting the zindex to -1 will place that layer behind all
others as they are loaded, keep in mind that only one background layer
at a time can be used, but you can have as many set to -1 as you like.
All other layers that are not set to -1 will be place on top of the
interface.
You can also see the results in this interface by examining the Mapbook
(I would check with FireBug in Firefox if possible):
https://gis.ci.stpaul.mn.us/gis/gismo_public/html/
All the "Background" layer have a setting of "-1", which you can see
here:
https://gis.ci.stpaul.mn.us/datasets/CONFIGS/SAINT_PAUL/PUBLIC_WORKS/MAPBOOKS/TS/gismo3_public.xml
Excerpt from above:
/datasets/RASTER/SAINT_PAUL/PUBLIC_WORKS/AERIAL_CITIPIX/citipix_2001_public.map
/datasets/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1985_public.map
/datasets/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1974_public.map
/datasets/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1953_public.map
/datasets/RASTER/RAMSEY_COUNTY/PUBLIC_WORKS/AERIAL_RAMSEY/rswcd_1940_public.map
hosejones1 at yahoo.com wrote:
> Dear Sir.
> My name is Joze. I am using ESRI Arcview, ArcMap..... at work.  I have
a task to build a mapserver .
>      I have chosed a MS4W instalation pack for Win. And GeoMoose
aplication. I have made the shapes and point layers to be working great.
I have not been so Lucky with RASTERS. I have tried to add .Jpg .GIF,
TIFF,..... nothing realy works. maybe its the problem with compsing my
.map file. I really dont have a slightest clue any more. I have been
searching the internet for quite a while an tried lots of things but
nothing really works for me. The closest i got to showing a raster  over
geomoose is that when i put the raster on top  i can fade and unfade
(transparency) it and the shape layers underneath shows up.
> I would really appreciate any help .
> Thank you
> Sincerely Joze
****************  You can't be late until you show up.  ***************
************  You never learn anything by doing it right.  ************
***  War doesn't determine who's right. War determines who's left.  ***
No Cost - Get a month of Blockbuster Total Access now. Sweet deal for Yahoo! users and friends.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080331/c00c41ca/attachment.html
More information about the Geomoose-users mailing list
